Change from sd to emmc on jetson xavier nx
Hi! Im running a jetson xavier nx with sd card reader. I have now bought a new one that has a emmc instead of sd card. How can easily just clone the operating system with all settings and so on from the sd to the emmc? Is there a straightforward process?
The jetson nx developer kit is two years old, the other one is bought from seed studio from today. Can there be some compatible issues down the line or shall it be a stragith forward cloning process?
Xavier NX SD/eMMC uses different device tree blob, so backup image cannot be shared between these two devices.
Cloning/backing up is only possible when you have two devices that are excatly the same.
Please manually copy files you need.
