Change image resolution using v4l2 api
I am using encoder using v4l2 api
I am able to stream in and out
BUT I also need to change to resolution of input frame (image height and width)
If trying to set format of output and capture after setting it first time the function failed
How can I change the resolution without closing and opening the file descriptor?
hello alalieli,
may I know what’s the actual use-case?
how many sensor modes you had? would you like to use 2D engine to crop/scale the frames for your use-case?
