Hi everyone,
I have a LI-IMX219-MIPI-FF-NANO-H90 from leopard imaging on a Jetson Nano 4GB. I want to capture an image at 120fps using the full sensor. When I try to use the full sensor I get an image which is about 4k, but at 30FPS.
I can open a video stream in OpenCV with gstreamer at 720p at 120 FPS the problem however is that it isn’t the full sensor. I open the camera in C++ with OpenCV the same way as C++ example on the JetsonHacks Github.
I get the following modes back if I use the example command on the main JetsonHacks CSI-Camera github page:
jetson@nano:~$ gst-launch-1.0 nvarguscamerasrc sensor_id=0 ! 'video/x-raw(memory:NVMM),width=1280, height=720, framerate=120/1, format=NV12' ! nvvidconv flip-method=0 ! 'video/x-raw,width=1280, height=720' ! nvvidconv ! nvegltransform ! nveglglessink -e
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 3264 x 2464 FR = 21,000000 fps Duration = 47619048 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 3264 x 1848 FR = 28,000001 fps Duration = 35714284 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1920 x 1080 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1640 x 1232 FR = 29,999999 fps Duration = 33333334 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 59,999999 fps Duration = 16666667 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: 1280 x 720 FR = 120,000005 fps Duration = 8333333 ; Analog Gain range min 1,000000, max 10,625000; Exposure Range min 13000, max 683709000;
GST_ARGUS: Running with following settings:
Camera index = 0
Camera mode = 5
Output Stream W = 1280 H = 720
seconds to Run = 0
Frame Rate = 120,000005
I have read that you can edit the register in the IMX219 sensor through I2C to change the binning to for eg. 4x4, but I can’t figure out how to do it. I understand that the register address is a 16-bit address. I tried to read the register using the command:
sudo i2ctransfer -f -y 6 w2@0x50 0x01 0x74 r1
Which should read the address at 0x174 from the register which default should be 0
according to this datasheet. however I get 0x2d
back which is the same as the value at 0x02
i2cdump:
jetson@nano:~$ i2cdump -y 6 0x50
No size specified (using byte-data access)
0 1 2 3 4 5 6 7 8 9 a b c d e f 0123456789abcdef
00: 4c 49 2d 49 4d 58 32 31 39 2d 4d 49 50 49 2d 46 LI-IMX219-MIPI-F
10: 46 2d 4e 41 4e 4f 2d 48 39 30 ff ff ff ff ff ff F-NANO-H90......
20: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
40: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
60: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
70: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
Is it possible to capture with the full sensor at 720@120FPS there seems to be alot of conflicting information about this and I can’t figure it out.
Thanks in advance.
