hi,
i works on jetson xavier nx box by jetpack5.0.2 and deepstream6.1.1.
at transfer_learning app’s overlay probe, i try to change color of roi line but failed:
display_meta->text_params[0].font_params.font_name = serif;
display_meta->text_params[0].set_bg_clr = 1;
display_meta->text_params[0].text_bg_clr = (NvOSD_ColorParams) {0, 0, 0, 1.0};
//display_meta->line_params[0].line_width = 15;
//display_meta->line_params[0].line_color = (NvOSD_ColorParams) {0, 1, 0, 1};
i also tried frame_meta_list again but failed, too. it seems that over_lay probe doesn’t be implemented at that app.
pls help to check the code and give some advices,
thank you very much!
