Change the frame rate of rtsp server (drop frames)
I have a pipeline similar to deepstream_test1_rtsp_in_rtsp_out:
I want to process all incoming frames by RTSP but want to reduce the number of frames by half in the out RTSP stream. how can I control the RTSP server frame rate? I tried Valve (by making it true and false every other frame) and videorate but it causes the whole pipeline doesn’t process any frame.
Could you try to use the videorate plugin to control that?
