Change the Instance Segmentation color for each tracker-id with deepstream_reference_app
• Hardware Platform (Jetson / GPU): GPU
• DeepStream Version: 6.0
• TensorRT Version: 8.0.1
• NVIDIA GPU Driver Version (valid for GPU only): 470.103.01
• Issue Type( questions, new requirements, bugs): questions
Hi.
I run PeopleSegNet model with deepstream_reference_app and I would like to change the Instance Segmentation color for each tracking-id. Is it possible with deepstream_reference_app?
I use this config file. deepstream_app_source1_mrcnn.txt
Yes. You can add one probe function and change color in the meta data.
Thanks. I’ll check out the Deepstream Plugin Guide and then try it.
