I m using jetson nano devkit and i have used linux for tegra to build the kernel and bootloader. I want to change the USB2.0 #0 from otg mode to host mode, for that i m doing the change in dtsi(tegra210-porg-p3448-common.dtsi) file in …/Linux_for_Tegra/hardware/nvidia/platform/t210/porg/kernel-dts. But I think its not working what i have to do for this?
For “devkit”, this cannot work because of the hardware design. Need to make your own custom board to make it work.
@WayneWWW
Hii, thank you for the reply. What if we have our custom board then how the procedure will be of changing the USB2.0 from otg mode to host mode.
We have the guidance for usb configuration in adaptation guide document. You can download it from our download center.
For hardware part, please refer to product design guide.
