Below serial console log is when the tx2 module bcpu temperature is up to 90C, we shutdown the system and start up it again
cr login: [0000.133] C> I2C command failed
[0000.136] C> block index = (4) and rail_id = (1)
[0000.140] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.145] C> I2C command failed
[0000.148] C> block index = (5) and rail_id = (1)
[0000.152] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.255] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-1b8ce67c)
[0000.263] I> bit @ 0xd480000
[0000.266] I> Boot-device: eMMC
[0000.270] I> sdmmc bdev is already initialized
[0000.275] I> pmic: reset reason (nverc) : 0x74
[0000.281] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0000.288] I> Found 30 partitions in SDMMC_USER (instance 3)
[0000.294] I> A/B: bin_type (16) slot 0
[0000.298] I> Loading partition bpmp-fw at 0xd7800000
[0000.303] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.308] I> Addr: 0xd7800000, start-block: 29417480, num_blocks: 1
[0000.323] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.329] I> A/B: bin_type (17) slot 0
[0000.332] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.337] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.343] I> Addr: 0xd79f0000, start-block: 29419896, num_blocks: 1
[0000.356] I> Binary(17) of size 314896 is loaded @ 0xd79b3000
[0000.478] I> Loading SCE-FW ...
[0000.481] I> A/B: bin_type (12) slot 0
[0000.485] I> Loading partition sce-fw at 0xd7300000
[0000.490] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.495] I> Addr: 0xd7300000, start-block: 29421896, num_blocks: 1
[0000.506] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.511] I> Init SCE
[0000.514] I> Loading APE-FW ...
[0000.517] I> A/B: bin_type (11) slot 0
[0000.520] I> Loading partition adsp-fw at 0xd7400000
[0000.525] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.531] I> Addr: 0xd7400000, start-block: 29401096, num_blocks: 1
[0000.541] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.547] I> Copy BTCM section
[0000.550] I> A/B: bin_type (13) slot 0
[0000.554] I> Loading partition cpu-bootloader at 0x96000000
[0000.559] I> Reading two headers - addr:0x96000000 blocks:1
[0000.565] I> Addr: 0x96000000, start-block: 29380616, num_blocks: 1
[0000.577] I> Binary(13) of size 277776 is loaded @ 0x96000000
[0000.583] I> A/B: bin_type (20) slot 0
[0000.586] I> Loading partition bootloader-dtb at 0x8520f400
[0000.592] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.597] I> Addr: 0x8520f400, start-block: 29382664, num_blocks: 1
[0000.611] I> Binary(20) of size 250112 is loaded @ 0x8520f400
[0000.617] I> A/B: bin_type (14) slot 0
[0000.620] I> Loading partition secure-os at 0x8530f600
[0000.625] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.631] I> Addr: 0x8530f600, start-block: 29384712, num_blocks: 1
[0000.643] I> Binary(14) of size 312752 is loaded @ 0x8530f600
[0000.651] I> TOS boot-params @ 0x85000000
[0000.655] I> TOS params prepared
[0000.658] I> Loading EKS ...
[0000.661] I> A/B: bin_type (15) slot 0
[0000.664] I> Loading partition eks at 0x8590f800
[0000.669] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.674] I> Addr: 0x8590f800, start-block: 29397000, num_blocks: 1
[0000.683] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.688] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.693] I> Copied encrypted keys
[0000.697] I> boot profiler @ 0x175844000
[0000.701] I> boot profiler for TOS @ 0x175844000
[0000.705] I> Unhalting SCE
[0000.708] I> Primary Memory Start:80000000 Size:70000000
[0000.713] I> Extended Memory Start:f0110000 Size:856f0000
[0000.720] I> MB2(TBoot-BPMP) done
NOTICE: BL31: v1.3(release):a28d87f09
NOTICE: BL31: Built : 21:15:42, Aug 12 2019
ipc-unittest-main: 1519: Welcome to IPC unittest!!!
ipc-unittest-main: 1531: waiting forever
ipc-unittest-srv: 329: Init unittest services!!!
keystore-demo: 141: Hello world from keystore-demo app
keystore-demo: 207: main: EKB contents match expected value
exit called, thread 0xffffffffea87ad58, name trusty_app_2_7d18fc60-e9fc-11e8
platform_bootstrap_epilog: trusty bootstrap complete
[0001.027] I> Welcome to Cboot
[0001.030] I> Cboot Version: t186-dcb303f9
[0001.033] I> CPU-BL Params @ 0x175800000
[0001.037] I> 0) Base:0x00000000 Size:0x00000000
[0001.042] I> 1) Base:0x177f00000 Size:0x00100000
[0001.046] I> 2) Base:0x177e00000 Size:0x00100000
[0001.051] I> 3) Base:0x177d00000 Size:0x00100000
[0001.055] I> 4) Base:0x177c00000 Size:0x00100000
[0001.060] I> 5) Base:0x177b00000 Size:0x00100000
[0001.064] I> 6) Base:0x177800000 Size:0x00200000
[0001.069] I> 7) Base:0x177400000 Size:0x00400000
[0001.073] I> 8) Base:0x177a00000 Size:0x00100000
[0001.078] I> 9) Base:0x177300000 Size:0x00100000
[0001.082] I> 10) Base:0x176800000 Size:0x00800000
[0001.087] I> 11) Base:0x30000000 Size:0x00040000
[0001.091] I> 12) Base:0xf0000000 Size:0x00100000
[0001.096] I> 13) Base:0x30040000 Size:0x00001000
[0001.100] I> 14) Base:0x30048000 Size:0x00001000
[0001.104] I> 15) Base:0x30049000 Size:0x00001000
[0001.109] I> 16) Base:0x3004a000 Size:0x00001000
[0001.113] I> 17) Base:0x3004b000 Size:0x00001000
[0001.118] I> 18) Base:0x3004c000 Size:0x00001000
[0001.122] I> 19) Base:0x3004d000 Size:0x00001000
[0001.127] I> 20) Base:0x3004e000 Size:0x00001000
[0001.131] I> 21) Base:0x3004f000 Size:0x00001000
[0001.135] I> 22) Base:0x00000000 Size:0x00000000
[0001.140] I> 23) Base:0xf0100000 Size:0x00010000
[0001.144] I> 24) Base:0x00000000 Size:0x00000000
[0001.149] I> 25) Base:0x00000000 Size:0x00000000
[0001.153] I> 26) Base:0x00000000 Size:0x00000000
[0001.158] I> 27) Base:0x00000000 Size:0x00000000
[0001.162] I> 28) Base:0x84400000 Size:0x00400000
[0001.167] I> 29) Base:0x30000000 Size:0x00010000
[0001.171] I> 30) Base:0x178000000 Size:0x08000000
[0001.175] I> 31) Base:0x00000000 Size:0x00000000
[0001.180] I> 32) Base:0x176000000 Size:0x00600000
[0001.184] I> 33) Base:0x80000000 Size:0x70000000
[0001.189] I> 34) Base:0xf0110000 Size:0x856f0000
[0001.193] I> 35) Base:0x00000000 Size:0x00000000
[0001.198] I> 36) Base:0x00000000 Size:0x00000000
[0001.202] I> 37) Base:0x1772e0000 Size:0x00020000
[0001.207] I> 38) Base:0x84000000 Size:0x00400000
[0001.211] I> 39) Base:0x96000000 Size:0x02000000
[0001.216] I> 40) Base:0x85000000 Size:0x01200000
[0001.220] I> 41) Base:0x175800000 Size:0x00500000
[0001.224] I> 42) Base:0x00000000 Size:0x00000000
[0001.229] I> 43) Base:0x00000000 Size:0x00000000
[0001.233] GIC-SPI Target CPU: 4
[0001.237] Interrupts Init done
[0001.240] calling constructors
[0001.243] initializing heap
[0001.246] initializing threads
[0001.249] initializing timers
[0001.252] creating bootstrap completion thread
[0001.257] top of bootstrap2()
[0001.260] CPU: ARM Cortex A57
[0001.263] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.268] initializing platform
[0001.271] I> Boot-device: eMMC
[0001.276] I> sdmmc bdev is already initialized
[0001.281] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0001.287] I> Found 30 partitions in SDMMC_USER (instance 3)
[0001.293] W> opt-in fuse is not set, skip fuse_burning
[0001.298] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.304] W> No valid slot number is found in scratch register
[0001.309] W> Return default slot: _a
[0001.313] I> A/B: bin_type (21) slot 0
[0001.316] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.330] I> Kernel_dtb @0x80000000
[0001.334] I> Bl_dtb @0x8520f400
[0001.337] I> gpio framework initialized
[0001.342] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.351] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.359] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.367] E> I2C: slave not found in slaves.
[0001.371] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start false.
[0001.379] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.385] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0x00000004 via instance 0.
[0001.394] E> tca9539_device_init: failed to write polar reg
[0001.399] E> tegrabl_tca9539_init: failed to init device!
[0001.405] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.411] E> I2C: slave not found in slaves.
[0001.416] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start false.
[0001.423] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.429] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0x00000004 via instance 0.
[0001.438] E> tca9539_device_init: failed to write polar reg
[0001.444] E> tegrabl_tca9539_init: failed to init device!
[0001.451] I> fixed regulator driver initialized
[0001.477] I> register 'maxim' power off handle
[0001.483] I> virtual i2c enabled
[0001.486] I> registered 'maxim,max77620' pmic
[0001.490] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.500] I> Find /i2c@c250000's alias i2c7
[0001.504] I> Reading eeprom i2c=7 address=0x50
[0001.533] I> Device at /i2c@c250000:0x50
[0001.537] I> Reading eeprom i2c=7 address=0x57
[0001.542] E> I2C: slave not found in slaves.
[0001.546] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.553] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.559] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.569] E> eeprom: Failed to read I2C slave device
[0001.574] I> Eeprom read failed 0x3526070d
[0001.578] I> Find /i2c@c240000's alias i2c1
[0001.582] I> Reading eeprom i2c=1 address=0x51
[0001.587] E> I2C: slave not found in slaves.
[0001.591] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.599] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.605] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.615] E> eeprom: Retry to read I2C slave device.
[0001.619] E> I2C: slave not found in slaves.
[0001.624] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.631] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.637] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.647] E> eeprom: Failed to read I2C slave device
[0001.651] I> Eeprom read failed 0x3526070d
[0001.656] I> Find /i2c@3160000's alias i2c0
[0001.660] I> Reading eeprom i2c=0 address=0x50
[0001.664] E> I2C: slave not found in slaves.
[0001.668] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.676] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.682] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.692] E> eeprom: Failed to read I2C slave device
[0001.696] I> Eeprom read failed 0x3526070d
[0001.701] I> Find /i2c@3180000's alias i2c2
[0001.705] I> Reading eeprom i2c=2 address=0x54
[0001.709] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.714] C> GPIO driver for chip_id 0x2 could not be found
[0001.720] E> cam_eeprom_read: Can't get gpio driver
[0001.724] I> Eeprom read failed 0x4d4d000d
[0001.728] I> Reading eeprom i2c=2 address=0x57
[0001.732] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.737] C> GPIO driver for chip_id 0x2 could not be found
[0001.743] E> cam_eeprom_read: Can't get gpio driver
[0001.747] I> Eeprom read failed 0x4d4d000d
[0001.751] I> create_pm_ids: id: 3489-0888-300-R, len: 15
[0001.756] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 3
[0001.782] I> enabling 'vdd-hdmi' regulator
[0001.786] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.799] E> no regulator info present for avdd_hdmi-supply
[0001.804] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.812] E> cannot find any other nvdisp nodes
[0001.817] E> no valid display unit config found in dtb
[0001.822] W> display init failed
[0001.825] initializing target
[0001.828] calling apps_init()
[0001.832] starting app kernel_boot_app
[0001.838] I> found decompressor handler: lz4-legacy
[0001.843] I> decompressing BMP blob ...
[0001.853] I> Kernel type = Normal
[0001.856] I> Loading kernel from partition ...
[0001.861] W> No valid slot number is found in scratch register
[0001.866] W> Return default slot: _a
[0001.870] I> A/B: bin_type (24) slot 0
[0001.879] I> Boot image size read from image header: f2d10
[0001.884] I> Boot image load address: 0x0x80400000
[0001.889] I> Loading partition kernel at 0x80400000 from device(0x1)
[0002.641] I> Kernel hdr @0x80400000
[0002.645] I> Kernel dtb @0x80000000
[0002.648] I> T18x: Authenticate boot.img (bin_type 24), max size 0x4000000
[0002.656] I> T18x: Authenticate tegra194-p2888-0001-p2822-0000.dtb (bin_type 21), max size 0x100000
[0002.665] I> Checking boot.img header magic ... [0002.669] I> [OK]
[0002.671] I> Valid boot.img @ 0x80400000
[0002.675] I> decompressor handler not found
[0002.679] I> Copying kernel image (477378 bytes) from 0x80400800 to 0x80800000 ... [0002.686] I> Done
[0002.688] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0002.695] I> Updated bpmp info to DTB
[0002.700] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0002.705] I> Updated initrd info to DTB
[0002.708] W> WARN: Fail to override "console=none" in commandline
[0002.714] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.721] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.729] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.736] I> disabled_core_mask: 0xffffff0c
[0002.740] W> No valid slot number is found in scratch register
[0002.745] W> Return default slot: _a
[0002.749] I> Active slot suffix:
[0002.752] I> add_boot_slot_suffix: slot_suffix =
[0002.756] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map
[0002.793] I> Updated bootarg info to DTB
[0002.797] W> MAC addr invalid!
[0002.800] E> Failed to get WIFI MAC address
[0002.804] W> MAC addr invalid!
[0002.806] E> Failed to get Bluetooth MAC address
[0002.811] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:68:63:ea
[0002.818] E> Found no plugin manager ids in source DT
[0002.823] W> Add plugin manager ids from board info
[0002.828] E> "plugin-manager" doesn't exist, creating
[0002.833] E> "ids" doesn't exist, creating
[0002.837] E> "connection" doesn't exist, creating
[0002.841] E> "configs" doesn't exist, creating
[0002.846] I> create_pm_ids: id: 3489-0888-300-R, len: 15
[0002.851] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 3
[0002.862] I> Adding plugin-manager/ids/3489-0888-300=/i2c@c250000:module@0x50
[0002.869] E> "i2c@c250000" doesn't exist, creating
[0002.873] E> "module@0x50" doesn't exist, creating
[0002.879] I> Adding plugin-manager/ids/3489-0888-300-R
[0002.886] I> Adding plugin-manager/configs/3489-mem-type 00
[0002.891] I> Adding plugin-manager/configs/3489-power-config 00
[0002.897] I> Adding plugin-manager/configs/3489-misc-config 00
[0002.903] I> Adding plugin-manager/configs/3489-modem-config 00
[0002.909] I> Adding plugin-manager/configs/3489-touch-config 00
[0002.915] I> Adding plugin-manager/configs/3489-display-config 00
[0002.921] I> Adding plugin-manager/cvm
[0002.925] E> "chip-id" doesn't exist, creating
[0002.929] I> Adding plugin-manager/chip-id/A02P
[0002.934] E> "odm-data" doesn't exist, creating
[0002.938] I> Adding /chosen/plugin-manager/odm-data
[0002.947] I> added [base:0x80000000, size:0x70000000] to /memory
[0002.952] I> added [base:0xf0200000, size:0x85600000] to /memory
[0002.958] I> added [base:0x175e00000, size:0x200000] to /memory
[0002.964] I> added [base:0x176600000, size:0x200000] to /memory
[0002.970] I> added [base:0x177000000, size:0x200000] to /memory
[0002.975] I> Updated memory info to DTB
[0002.980] E> add_disp_param: failed to get display params for du=0
[0002.987] E> "reset" doesn't exist, creating
[0002.991] E> "pmc-reset-reason" doesn't exist, creating
[0002.996] E> "pmic-reset-reason" doesn't exist, creating
[0003.002] I> Adding ecid(00000001642d12091400000005fb0340) to DT
[0003.008] I> disabled_core_mask: 0xffffff0c
[0003.018] I> Add serial number:1420822055700 as DT property
[0003.026] I> Plugin-manager override starting
[0003.031] I> node /plugin-manager/fragement@0 matches
[0003.039] I> node /plugin-manager/fragement@4 matches
[0003.065] I> Disable plugin-manager status in FDT
[0003.070] I> Plugin-manager override finished successfully
[0003.075] I> tegrabl_load_kernel_and_dtb: Done
[0003.080] E> tegrabl_display_clear: display is not initialized
[0003.085] W> Boot logo display failed...
[0003.089] I> Kernel EP: 0x80800000, DTB: 0x80000000
U-Boot 2016.07-gd917e08cec (Aug 12 2019 - 21:16:16 -0700)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 3.8 GiB
MC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 1 �[0000.112] C> I2C command failed
[0000.115] C> block index = (4) and rail_id = (1)
[0000.120] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.124] C> I2C command failed
[0000.127] C> block index = (5) and rail_id = (1)
[0000.132] C> Addr: Reg = [0xe8:0x07]: 336166925
[0000.234] I> Welcome to MB2(TBoot-BPMP)(version: 01.00.160913-t186-M-00.00-mobile-1b8ce67c)
[0000.243] I> bit @ 0xd480000
[0000.246] I> Boot-device: eMMC
[0000.250] I> sdmmc bdev is already initialized
[0000.254] I> pmic: reset reason (nverc) : 0x4
[0000.260] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0000.267] I> Found 30 partitions in SDMMC_USER (instance 3)
[0000.273] I> A/B: bin_type (16) slot 0
[0000.277] I> Loading partition bpmp-fw at 0xd7800000
[0000.282] I> Reading two headers - addr:0xd7800000 blocks:1
[0000.287] I> Addr: 0xd7800000, start-block: 29417480, num_blocks: 1
[0000.302] I> Binary(16) of size 533504 is loaded @ 0xd7800000
[0000.308] I> A/B: bin_type (17) slot 0
[0000.312] I> Loading partition bpmp-fw-dtb at 0xd79f0000
[0000.317] I> Reading two headers - addr:0xd79f0000 blocks:1
[0000.322] I> Addr: 0xd79f0000, start-block: 29419896, num_blocks: 1
[0000.335] I> Binary(17) of size 314896 is loaded @ 0xd79b3000
[0000.457] I> Loading SCE-FW ...
[0000.460] I> A/B: bin_type (12) slot 0
[0000.464] I> Loading partition sce-fw at 0xd7300000
[0000.468] I> Reading two headers - addr:0xd7300000 blocks:1
[0000.474] I> Addr: 0xd7300000, start-block: 29421896, num_blocks: 1
[0000.484] I> Binary(12) of size 125168 is loaded @ 0xd7300000
[0000.490] I> Init SCE
[0000.492] I> Loading APE-FW ...
[0000.495] I> A/B: bin_type (11) slot 0
[0000.499] I> Loading partition adsp-fw at 0xd7400000
[0000.504] I> Reading two headers - addr:0xd7400000 blocks:1
[0000.509] I> Addr: 0xd7400000, start-block: 29401096, num_blocks: 1
[0000.520] I> Binary(11) of size 107808 is loaded @ 0xd7400000
[0000.526] I> Copy BTCM section
[0000.529] I> A/B: bin_type (13) slot 0
[0000.532] I> Loading partition cpu-bootloader at 0x96000000
[0000.538] I> Reading two headers - addr:0x96000000 blocks:1
[0000.543] I> Addr: 0x96000000, start-block: 29380616, num_blocks: 1
[0000.555] I> Binary(13) of size 277776 is loaded @ 0x96000000
[0000.561] I> A/B: bin_type (20) slot 0
[0000.565] I> Loading partition bootloader-dtb at 0x8520f400
[0000.570] I> Reading two headers - addr:0x8520f400 blocks:1
[0000.576] I> Addr: 0x8520f400, start-block: 29382664, num_blocks: 1
[0000.590] I> Binary(20) of size 250112 is loaded @ 0x8520f400
[0000.595] I> A/B: bin_type (14) slot 0
[0000.599] I> Loading partition secure-os at 0x8530f600
[0000.604] I> Reading two headers - addr:0x8530f600 blocks:1
[0000.609] I> Addr: 0x8530f600, start-block: 29384712, num_blocks: 1
[0000.622] I> Binary(14) of size 312752 is loaded @ 0x8530f600
[0000.630] I> TOS boot-params @ 0x85000000
[0000.633] I> TOS params prepared
[0000.637] I> Loading EKS ...
[0000.639] I> A/B: bin_type (15) slot 0
[0000.643] I> Loading partition eks at 0x8590f800
[0000.647] I> Reading two headers - addr:0x8590f800 blocks:1
[0000.653] I> Addr: 0x8590f800, start-block: 29397000, num_blocks: 1
[0000.661] I> Binary(15) of size 1040 is loaded @ 0x8590f800
[0000.667] I> EKB detected (length: 0x400) @ 0x8590f800
[0000.672] I> Copied encrypted keys
[0000.675] I> boot profiler @ 0x175844000
[0000.679] I> boot profiler for TOS @ 0x175844000
[0000.684] I> Unhalting SCE
[0000.687] I> Primary Memory Start:80000000 Size:70000000
[0000.692] I> Extended Memory Start:f0110000 Size:856f0000
[0000.698] I> MB2(TBoot-BPMP) done
[0001.005] I> Welcome to Cboot
[0001.008] I> Cboot Version: t186-dcb303f9
[0001.012] I> CPU-BL Params @ 0x175800000
[0001.015] I> 0) Base:0x00000000 Size:0x00000000
[0001.020] I> 1) Base:0x177f00000 Size:0x00100000
[0001.024] I> 2) Base:0x177e00000 Size:0x00100000
[0001.029] I> 3) Base:0x177d00000 Size:0x00100000
[0001.033] I> 4) Base:0x177c00000 Size:0x00100000
[0001.038] I> 5) Base:0x177b00000 Size:0x00100000
[0001.042] I> 6) Base:0x177800000 Size:0x00200000
[0001.047] I> 7) Base:0x177400000 Size:0x00400000
[0001.052] I> 8) Base:0x177a00000 Size:0x00100000
[0001.056] I> 9) Base:0x177300000 Size:0x00100000
[0001.061] I> 10) Base:0x176800000 Size:0x00800000
[0001.065] I> 11) Base:0x30000000 Size:0x00040000
[0001.069] I> 12) Base:0xf0000000 Size:0x00100000
[0001.074] I> 13) Base:0x30040000 Size:0x00001000
[0001.078] I> 14) Base:0x30048000 Size:0x00001000
[0001.083] I> 15) Base:0x30049000 Size:0x00001000
[0001.087] I> 16) Base:0x3004a000 Size:0x00001000
[0001.092] I> 17) Base:0x3004b000 Size:0x00001000
[0001.096] I> 18) Base:0x3004c000 Size:0x00001000
[0001.101] I> 19) Base:0x3004d000 Size:0x00001000
[0001.105] I> 20) Base:0x3004e000 Size:0x00001000
[0001.109] I> 21) Base:0x3004f000 Size:0x00001000
[0001.114] I> 22) Base:0x00000000 Size:0x00000000
[0001.118] I> 23) Base:0xf0100000 Size:0x00010000
[0001.123] I> 24) Base:0x00000000 Size:0x00000000
[0001.127] I> 25) Base:0x00000000 Size:0x00000000
[0001.132] I> 26) Base:0x00000000 Size:0x00000000
[0001.136] I> 27) Base:0x00000000 Size:0x00000000
[0001.140] I> 28) Base:0x84400000 Size:0x00400000
[0001.145] I> 29) Base:0x30000000 Size:0x00010000
[0001.149] I> 30) Base:0x178000000 Size:0x08000000
[0001.154] I> 31) Base:0x00000000 Size:0x00000000
[0001.158] I> 32) Base:0x176000000 Size:0x00600000
[0001.163] I> 33) Base:0x80000000 Size:0x70000000
[0001.167] I> 34) Base:0xf0110000 Size:0x856f0000
[0001.172] I> 35) Base:0x00000000 Size:0x00000000
[0001.176] I> 36) Base:0x00000000 Size:0x00000000
[0001.180] I> 37) Base:0x1772e0000 Size:0x00020000
[0001.185] I> 38) Base:0x84000000 Size:0x00400000
[0001.189] I> 39) Base:0x96000000 Size:0x02000000
[0001.194] I> 40) Base:0x85000000 Size:0x01200000
[0001.198] I> 41) Base:0x175800000 Size:0x00500000
[0001.203] I> 42) Base:0x00000000 Size:0x00000000
[0001.207] I> 43) Base:0x00000000 Size:0x00000000
[0001.212] GIC-SPI Target CPU: 4
[0001.215] Interrupts Init done
[0001.218] calling constructors
[0001.221] initializing heap
[0001.224] initializing threads
[0001.227] initializing timers
[0001.230] creating bootstrap completion thread
[0001.235] top of bootstrap2()
[0001.238] CPU: ARM Cortex A57
[0001.241] CPU: MIDR: 0x411FD073, MPIDR: 0x80000100
[0001.246] initializing platform
[0001.250] I> Boot-device: eMMC
[0001.255] I> sdmmc bdev is already initialized
[0001.260] I> Found 16 partitions in SDMMC_BOOT (instance 3)
[0001.266] I> Found 30 partitions in SDMMC_USER (instance 3)
[0001.271] W> opt-in fuse is not set, skip fuse_burning
[0001.276] I> Reserved memory at 0xfbe00000 for U-Boot relocation
[0001.282] W> No valid slot number is found in scratch register
[0001.288] W> Return default slot: _a
[0001.291] I> A/B: bin_type (21) slot 0
[0001.294] I> Loading partition kernel-dtb at 0x80000000 from device(0x1)
[0001.309] I> Kernel_dtb @0x80000000
[0001.312] I> Bl_dtb @0x8520f400
[0001.315] I> gpio framework initialized
[0001.320] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio' driver
[0001.329] I> tegrabl_gpio_driver_register: register 'nvidia,tegra186-gpio-aon' driver
[0001.337] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xee
[0001.345] E> I2C: slave not found in slaves.
[0001.349] E> I2C: Could not write 0 bytes to slave: 0x00ee with repeat start false.
[0001.357] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.363] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xee at 0x00000004 via instance 0.
[0001.372] E> tca9539_device_init: failed to write polar reg
[0001.378] E> tegrabl_tca9539_init: failed to init device!
[0001.383] I> tegrabl_tca9539_init: i2c bus: 0, slave addr: 0xe8
[0001.390] E> I2C: slave not found in slaves.
[0001.394] E> I2C: Could not write 0 bytes to slave: 0x00e8 with repeat start false.
[0001.402] E> I2C_DEV: Failed to send register address 0x00000004.
[0001.408] E> I2C_DEV: Could not write 1 registers of size 1 to slave 0xe8 at 0x00000004 via instance 0.
[0001.417] E> tca9539_device_init: failed to write polar reg
[0001.422] E> tegrabl_tca9539_init: failed to init device!
[0001.429] I> fixed regulator driver initialized
[0001.456] I> register 'maxim' power off handle
[0001.461] I> virtual i2c enabled
[0001.464] I> registered 'maxim,max77620' pmic
[0001.468] I> tegrabl_gpio_driver_register: register 'max77620-gpio' driver
[0001.478] I> Find /i2c@c250000's alias i2c7
[0001.482] I> Reading eeprom i2c=7 address=0x50
[0001.512] I> Device at /i2c@c250000:0x50
[0001.516] I> Reading eeprom i2c=7 address=0x57
[0001.520] E> I2C: slave not found in slaves.
[0001.524] E> I2C: Could not write 0 bytes to slave: 0x00ae with repeat start true.
[0001.532] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.538] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xae at 0x00000000 via instance 7.
[0001.547] E> eeprom: Failed to read I2C slave device
[0001.552] I> Eeprom read failed 0x3526070d
[0001.557] I> Find /i2c@c240000's alias i2c1
[0001.561] I> Reading eeprom i2c=1 address=0x51
[0001.566] E> I2C: slave not found in slaves.
[0001.570] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.578] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.583] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.593] E> eeprom: Retry to read I2C slave device.
[0001.598] E> I2C: slave not found in slaves.
[0001.602] E> I2C: Could not write 0 bytes to slave: 0x00a2 with repeat start true.
[0001.610] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.616] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa2 at 0x00000000 via instance 1.
[0001.625] E> eeprom: Failed to read I2C slave device
[0001.630] I> Eeprom read failed 0x3526070d
[0001.634] I> Find /i2c@3160000's alias i2c0
[0001.638] I> Reading eeprom i2c=0 address=0x50
[0001.643] E> I2C: slave not found in slaves.
[0001.647] E> I2C: Could not write 0 bytes to slave: 0x00a0 with repeat start true.
[0001.655] E> I2C_DEV: Failed to send register address 0x00000000.
[0001.660] E> I2C_DEV: Could not read 256 registers of size 1 from slave 0xa0 at 0x00000000 via instance 0.
[0001.670] E> eeprom: Failed to read I2C slave device
[0001.675] I> Eeprom read failed 0x3526070d
[0001.679] I> Find /i2c@3180000's alias i2c2
[0001.683] I> Reading eeprom i2c=2 address=0x54
[0001.688] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.693] C> GPIO driver for chip_id 0x2 could not be found
[0001.698] E> cam_eeprom_read: Can't get gpio driver
[0001.703] I> Eeprom read failed 0x4d4d000d
[0001.707] I> Reading eeprom i2c=2 address=0x57
[0001.711] I> Enabling gpio chip_id = 2, gpio pin = 9
[0001.716] C> GPIO driver for chip_id 0x2 could not be found
[0001.721] E> cam_eeprom_read: Can't get gpio driver
[0001.726] I> Eeprom read failed 0x4d4d000d
[0001.730] I> create_pm_ids: id: 3489-0888-300-R, len: 15
[0001.735] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 3
[0001.760] I> enabling 'vdd-hdmi' regulator
[0001.764] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.777] E> no regulator info present for avdd_hdmi-supply
[0001.783] E> tegrabl_display_get_pdata, failed to parse dtb settings
[0001.791] E> cannot find any other nvdisp nodes
[0001.795] E> no valid display unit config found in dtb
[0001.801] W> display init failed
[0001.804] initializing target
[0001.807] calling apps_init()
[0001.810] starting app kernel_boot_app
[0001.820] I> found decompressor handler: lz4-legacy
[0001.825] I> decompressing BMP blob ...
[0001.835] I> Kernel type = Normal
[0001.838] I> Loading kernel from partition ...
[0001.842] W> No valid slot number is found in scratch register
[0001.848] W> Return default slot: _a
[0001.852] I> A/B: bin_type (24) slot 0
[0001.861] I> Boot image size read from image header: f2d10
[0001.866] I> Boot image load address: 0x0x80400000
[0001.870] I> Loading partition kernel at 0x80400000 from device(0x1)
[0002.623] I> Kernel hdr @0x80400000
[0002.626] I> Kernel dtb @0x80000000
[0002.629] I> T18x: Authenticate boot.img (bin_type 24), max size 0x4000000
[0002.637] I> T18x: Authenticate tegra194-p2888-0001-p2822-0000.dtb (bin_type 21), max size 0x100000
[0002.646] I> Checking boot.img header magic ... [0002.651] I> [OK]
[0002.652] I> Valid boot.img @ 0x80400000
[0002.656] I> decompressor handler not found
[0002.660] I> Copying kernel image (477378 bytes) from 0x80400800 to 0x80800000 ... [0002.668] I> Done
[0002.669] I> Move ramdisk (len: 0) from 0x80475800 to 0x94830000
[0002.676] I> Updated bpmp info to DTB
[0002.681] I> Ramdisk: Base: 0x94830000; Size: 0x0
[0002.686] I> Updated initrd info to DTB
[0002.690] W> WARN: Fail to override "console=none" in commandline
[0002.696] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.703] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.710] E> tegrabl_linuxboot_add_disp_param, du 0 failed to get display params
[0002.717] I> disabled_core_mask: 0xffffff0c
[0002.721] W> No valid slot number is found in scratch register
[0002.727] W> Return default slot: _a
[0002.730] I> Active slot suffix:
[0002.733] I> add_boot_slot_suffix: slot_suffix =
[0002.738] I> Linux Cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map
[0002.774] I> Updated bootarg info to DTB
[0002.778] W> MAC addr invalid!
[0002.781] E> Failed to get WIFI MAC address
[0002.785] W> MAC addr invalid!
[0002.788] E> Failed to get Bluetooth MAC address
[0002.792] I> eeprom_get_mac_addr: MAC (type: 2): 48:b0:2d:68:63:ea
[0002.800] E> Found no plugin manager ids in source DT
[0002.804] W> Add plugin manager ids from board info
[0002.809] E> "plugin-manager" doesn't exist, creating
[0002.814] E> "ids" doesn't exist, creating
[0002.818] E> "connection" doesn't exist, creating
[0002.823] E> "configs" doesn't exist, creating
[0002.827] I> create_pm_ids: id: 3489-0888-300-R, len: 15
[0002.832] I> config: mem-type:00,power-config:00,misc-config:00,modem-config:00,touch-config:00,display-config:00,, len: 3
[0002.843] I> Adding plugin-manager/ids/3489-0888-300=/i2c@c250000:module@0x50
[0002.850] E> "i2c@c250000" doesn't exist, creating
[0002.855] E> "module@0x50" doesn't exist, creating
[0002.861] I> Adding plugin-manager/ids/3489-0888-300-R
[0002.867] I> Adding plugin-manager/configs/3489-mem-type 00
[0002.873] I> Adding plugin-manager/configs/3489-power-config 00
[0002.879] I> Adding plugin-manager/configs/3489-misc-config 00
[0002.884] I> Adding plugin-manager/configs/3489-modem-config 00
[0002.890] I> Adding plugin-manager/configs/3489-touch-config 00
[0002.896] I> Adding plugin-manager/configs/3489-display-config 00
[0002.902] I> Adding plugin-manager/cvm
[0002.906] E> "chip-id" doesn't exist, creating
[0002.910] I> Adding plugin-manager/chip-id/A02P
[0002.915] E> "odm-data" doesn't exist, creating
[0002.919] I> Adding /chosen/plugin-manager/odm-data
[0002.928] I> added [base:0x80000000, size:0x70000000] to /memory
[0002.934] I> added [base:0xf0200000, size:0x85600000] to /memory
[0002.939] I> added [base:0x175e00000, size:0x200000] to /memory
[0002.945] I> added [base:0x176600000, size:0x200000] to /memory
[0002.951] I> added [base:0x177000000, size:0x200000] to /memory
[0002.957] I> Updated memory info to DTB
[0002.961] E> add_disp_param: failed to get display params for du=0
[0002.968] E> "reset" doesn't exist, creating
[0002.972] E> "pmc-reset-reason" doesn't exist, creating
[0002.978] E> "pmic-reset-reason" doesn't exist, creating
[0002.984] I> Adding ecid(00000001642d12091400000005fb0340) to DT
[0002.990] I> disabled_core_mask: 0xffffff0c
[0002.999] I> Add serial number:1420822055700 as DT property
[0003.007] I> Plugin-manager override starting
[0003.012] I> node /plugin-manager/fragement@0 matches
[0003.021] I> node /plugin-manager/fragement@4 matches
[0003.047] I> Disable plugin-manager status in FDT
[0003.051] I> Plugin-manager override finished successfully
[0003.057] I> tegrabl_load_kernel_and_dtb: Done
[0003.061] E> tegrabl_display_clear: display is not initialized
[0003.066] W> Boot logo display failed...
[0003.070] I> Kernel EP: 0x80800000, DTB: 0x80000000
TEGRA186
DRAM: 3.8 GiB
In: serial
Out: serial
Err: serial
Hit any key to stop autoboot: 0
MMC: no card present
switch to partitions #0, OK
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
145 bytes read in 77 ms (1000 Bytes/s)
1: primary kernel
Retrieving file: /boot/initrd
5565090 bytes read in 251 ms (21.1 MiB/s)
Retrieving file: /boot/Image
34248712 bytes read in 856 ms (38.2 MiB/s)
append: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 videt
## Flattened Device Tree blob at 80000000
Booting using the fdt blob at 0x80000000
reserving fdt memory region: addr=80000000 size=10000
Using Device Tree in place at 0000000080000000, end 0000000080042094
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x100
[ 0.000000] Linux version 4.9.140-tegra(#1 SMP PREEMPT Tue Feb 14 20:03:25 CST 2023) (jenkins@d-MS) (gcc version 7.3.1
[ 0.000000] Boot CPU: AArch64 Processor [411fd073]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 16416,
[ 0.000000] OF: fdt: - 80000000 , 70000000
[ 0.000000] OF: fdt: - f0200000 , 85600000
[ 0.000000] OF: fdt: - 175e00000 , 200000
[ 0.000000] OF: fdt: - 176600000 , 200000
[ 0.000000] OF: fdt: - 177000000 , 200000
[ 0.000000] earlycon: uart8250 at MMIO32 0x0000000003100000 (options '')
[ 0.000000] bootconsole [uart8250] enabled
<hit enter to activate fiq debugger>
[ 0.512549] pca953x 0-0074: failed reading register
[ 0.512970] pca953x 0-0077: failed reading register
[ 0.979860] tegradc 15210000.nvdisplay: dc_hdmi_hotplug_init: couldn't get regulator vdd_hdmi_5v0, -517
[ 1.738910] tc358748_parse_dt:parse dt
[ 1.738966] tc358748_ctrls_init: entry
[ 1.738968] tc358748_ctrls_init: numctrls 2
[ 1.738970] tc358748_ctrls_init: ctrl_config_list[i].id 10100745
[ 1.738979] tc358748_ctrls_init:init Gain ctrl
[ 1.738981] tc358748_ctrls_init: ctrl_config_list[i].id 10100740
[ 1.738983] tc358748_ctrls_init:init HDR enable ctrl
[ 1.739076] tc358748_parse_dt:parse dt
[ 1.739118] tc358748_ctrls_init: entry
[ 1.739119] tc358748_ctrls_init: numctrls 2
[ 1.739121] tc358748_ctrls_init: ctrl_config_list[i].id 10100745
[ 1.739125] tc358748_ctrls_init:init Gain ctrl
[ 1.739127] tc358748_ctrls_init: ctrl_config_list[i].id 10100740
[ 1.739129] tc358748_ctrls_init:init HDR enable ctrl
[ 1.739183] tc358748_parse_dt:parse dt
[ 1.739224] tc358748_ctrls_init: entry
[ 1.739226] tc358748_ctrls_init: numctrls 2
[ 1.739227] tc358748_ctrls_init: ctrl_config_list[i].id 10100745
[ 1.739232] tc358748_ctrls_init:init Gain ctrl
[ 1.739233] tc358748_ctrls_init: ctrl_config_list[i].id 10100740
[ 1.739235] tc358748_ctrls_init:init HDR enable ctrl
[ 1.739284] tc358748_parse_dt:parse dt
[ 1.739322] tc358748_ctrls_init: entry
[ 1.739323] tc358748_ctrls_init: numctrls 2
[ 1.739325] tc358748_ctrls_init: ctrl_config_list[i].id 10100745
[ 1.739329] tc358748_ctrls_init:init Gain ctrl
[ 1.739330] tc358748_ctrls_init: ctrl_config_list[i].id 10100740
[ 1.739332] tc358748_ctrls_init:init HDR enable ctrl
[ 1.746596] FAN: coudln't get the regulator
[ 1.785749] ina3221x 0-0042: ina3221 reset failure status: 0xffffff87
[ 1.786217] ina3221x 0-0043: ina3221 reset failure status: 0xffffff87
[ 4.997656] cgroup: cgroup2: unknown option "nsdelegate"
[ 5.675055] random: crng init done
[ 5.678487] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.394818] spidev: module is already loaded
[ 6.456514] spidev: module is already loaded
[ 6.469846] using random self ethernet address
[ 6.469852] using random host ethernet address
[ 6.517547] using random self ethernet address
[ 6.523018] using random host ethernet address
[ 7.396079] spidev: module is already loaded
[ 7.683105] watchdog: watchdog0: watchdog did not stop!
Ubuntu 18.04.2 LTS cr ttyS0
