Hi, KevinFFF
I just mention previous posts, below
When we set the value of cooldown_temp_threshold to 50000 below 86000, it takes effect;
When we set the value of cooldown_tmep_threshold to 99000 exceed 86000, it seems not take effect;
After we start up the system we can see below msg with tegrastates, so we have the conclusion;
RAM 2630/3835MB (lfb 140x4MB) SWAP 0/1917MB (cached 0MB) CPU [74%@960,off,off,79%@961,68%@961,66%@960] EMC_FREQ 29%@1331 GR3D_FREQ 11%@624 NVENC 115 APE 150 PLL@87.5C MCPU@87.5C PMIC@100C Tboard@86C GPU@86.5C BCPU@87.5C thermal@86.9C Tdiode@86.75C VDD_SYS_GPU 711/735 VDD_SYS_SOC 2088/2087 VDD_IN 6947/6959 VDD_SYS_CPU 616/616 VDD_SYS_DDR 1689/1693
RAM 2631/3835MB (lfb 140x4MB) SWAP 0/1917MB (cached 0MB) CPU [78%@959,off,off,77%@959,58%@960,63%@959] EMC_FREQ 29%@1331 GR3D_FREQ 38%@624 NVENC 115 APE 150 PLL@87.5C MCPU@87.5C PMIC@100C Tboard@86C GPU@86.5C BCPU@87.5C thermal@87.1C Tdiode@86.75C VDD_SYS_GPU 711/730 VDD_SYS_SOC 2040/2078 VDD_IN 6923/6951 VDD_SYS_CPU 616/616 VDD_SYS_DDR 1670/1689
RAM 2630/3835MB (lfb 140x4MB) SWAP 0/1917MB (cached 0MB) CPU [76%@961,off,off,75%@960,64%@960,68%@960] EMC_FREQ 29%@1331 GR3D_FREQ 12%@624 NVENC 115 APE 150 PLL@87.5C MCPU@87.5C PMIC@100C Tboard@86C GPU@86.5C BCPU@87.5C thermal@87.1C Tdiode@86.5C VDD_SYS_GPU 711/727 VDD_SYS_SOC 2088/2079 VDD_IN 6947/6951 VDD_SYS_CPU 616/616 VDD_SYS_DDR 1708/1692
RAM 2631/3835MB (lfb 139x4MB) SWAP 0/1917MB (cached 0MB) CPU [73%@960,off,off,79%@961,65%@961,60%@961] EMC_FREQ 28%@1331 GR3D_FREQ 98%@624 NVENC 115 APE 150 PLL@87.5C MCPU@87.5C PMIC@100C Tboard@86C GPU@86.5C BCPU@87.5C thermal@87.1C Tdiode@86.75C VDD_SYS_GPU 711/724 VDD_SYS_SOC 2040/2074 VDD_IN 6852/6936 VDD_SYS_CPU 616/616 VDD_SYS_DDR 1632/1683
If the cpu temperature higher than 86C, for example 96C , we need wait about 5 minutes when system boot resum.
if the cpu temperature 90C, cold boot the module, we wait about 2-3minutes when system boot resume.
In all, when system start up, we run tegrastates, the bcpu temperature is always around 86C;
It seems the value is up limit to 86000 in somewhere ?
