Changeable/Non-changeable variables in Isaac
Hello.
While implementing robot simulation with Isaac sim, I wondered if all the parameters that apply to the environment could change during the change in the simulation time.
For example, for domain randomization, I understand that some variables can be updated to match the reset signal.
Then, can variables such as ‘the control period of the articulator’(sim_dt, control_dt) be changed arbitrarily rather than fixed depending on the episode?
Thank you.
Hi there, the simulation time can be set using set_simulation_dt from the SimulationContext class. Not all parameters can be changed on the fly though, and it will probably require a world.reset() to do so.
