• Hardware Platform DGPU • DeepStream Version 6.0.1 • NVIDIA GPU Driver Version 510.85.02 • Issue Type( questions, new requirements, bugs)
I got this error, while changing filesink location in probe function.
** (python3:28641): WARNING **: 14:24:50.878: Changing the `location’ property on filesink when a file is open is not supported.
changing filesink location in probe function will give thar error
my pipeline
streammux->nvvideoconvert->capsfilter->inference->demux->queue->nvvideoconvert->valve->nv4l2h264enc->h264parse->avimux->filesink
how to change filesink location in the probe function?
As far as I know, you can’t change location in a probe function.
You can use splitmuxsink to emit a signal to change filename as per your condition.
Check splitmuxsink
You can emit split-now signal to trigger a file change event. And then you can create your filename in this callback
Error: gst-stream-error-quark: Could not multiplex stream. (10): gstqtmux.c(4561): gst_qt_mux_add_buffer (): /GstPipeline:pipeline0/GstSplitMuxSink:recording-sink2/GstMP4Mux:muxer:
Buffer has no PTS.
can you explain this and how to resolve this issue?
Umm, this usually happens when there is a timestamping issue in your buffers. Especially with RTSP streams where frames can drop frequently. mp4mux and qtmux are quite sensitive to this.
You can do a quick hack by changing your mux to matroskamux
I’ve been using splitmuxsink to split the recordings of a live video stream by length or by the “split now” cmd. The resulting video files are all timestamped with the “global time” from when the pipeline started.
File1 00:00 - 05:00
File2 05:00 - 10:00
File3 10:00 - 15:00
This is causing issues when playing back the files in certain video players that are expected a time stamp starting at 0.
What I’d like to do is reset the time stamping every time the recordings are split and a new file is started.
