I’m trying to interface a QCA9377 based SDIO wifi module with a custom carrier board that is powered by Jetson Xavier NX. I have been using the wifi driver(ath10k) and I’m facing an sdio issue where I dont get SDIO interrupts while scanning during mid scan. For debugging this issue I have been trying several methods in the sdio front and for one of them I’m trying to change the SDIO mode of transfer from DMA to PIO. How do i change the mode of operation from ADMA to PIO (PIO is supported as per the Xavier NX’s reference manual) ?
Could you try to use below patch in the sdhci driver?
diff --git a/drivers/mmc/host/sdhci-tegra.c b/drivers/mmc/host/sdhci-tegra.c
index a8e6a6d..67d96df 100644
--- a/drivers/mmc/host/sdhci-tegra.c
+++ b/drivers/mmc/host/sdhci-tegra.c
@@ -2037,6 +2037,8 @@ static const struct sdhci_pltfm_data sdhci_tegra194_pdata = {
SDHCI_QUIRK_NO_HISPD_BIT |
SDHCI_QUIRK_BROKEN_ADMA_ZEROLEN_DESC |
+ SDHCI_QUIRK_BROKEN_DMA |
+ SDHCI_QUIRK_BROKEN_ADMA |
SDHCI_QUIRK_NO_ENDATTR_IN_NOPDESC,
.quirks2 = SDHCI_QUIRK2_PRESET_VALUE_BROKEN |
SDHCI_QUIRK2_USE_64BIT_ADDR |
