Hi:
I would like to know if it is possible to change “the number of runs” of a program in the Compute Visual Profiler
jpeinado
Hi:
jpeinado
I haven’t used the profiler for a long time. But as far as I remember, it always chooses the minimal number of runs possible. The profiler only uses multiple runs if the hardware is not capable of gathering all requested info in a single pass.
Hi:
Thank you very much for your help. In former versions (3 and down) it was as you tell. But the problem is, that I think version 4 changed this. It runs alwasys for 15 times. My problem is that the main program is in MATLAB, that later calls to CUDA routines. It only works OK, the first time.
Anyway, Thank you very much
Regards.
jpeinado
