We have rebuilt the container with enable_srs set to 1 in cuphycontroller_P5G_FXN_R750.yaml, and have added a printf statement in cuphyRunSrsRx to check if that part of the code is active. However, the printf statement is never executed. We have tried to activate the debug log. But the container does not start when shm_log_level is set to 6 or 7 in cuPHY/nvlog/config/nvlog_config.yaml, and exits with following error:
nv-cubb | /opt/nvidia/cuBB/aerial_l1_entrypoint.sh: line 38: 44 Segmentation fault sudo -E "$cuBB_Path"/build/cuPHY-CP/cuphycontroller/examples/cuphycontroller_scf "$argument"
nv-cubb | 20:01:11.574064 nvlog.cpp:404 WRN[80 ] [NVIPC.PCAP] Usage: ./build/cuPHY-CP/gt_common_libs/nvIPC/tests/pcap/pcap_collect <name> <destination path>
nv-cubb |
nv-cubb | 20:01:11.574069 nvlog.cpp:404 WRN[80 ] [NVIPC.PCAP] Current run: ./build/cuPHY-CP/gt_common_libs/nvIPC/tests/pcap/pcap_collect name=nvipc dest_path=.
nv-cubb |
nv-cubb | 20:01:11.574088 nvlog.cpp:413 ERR[80 ] [NVIPC.SHM] [AERIAL_SYSTEM_API_EVENT] ipc_shm_open: shm_open nvipc_cfg_app_config failed error -1
nv-cubb | 20:01:11.574089 nvlog.cpp:413 ERR[80 ] [NVIPC.SHM] [AERIAL_NVIPC_API_EVENT] nv_ipc_shm_open: primary=0 name=nvipc_cfg_app_config Failed
nv-cubb | 20:01:11.574091 nvlog.cpp:413 ERR[80 ] [NVIPC.SHM] [AERIAL_SYSTEM_API_EVENT] ipc_shm_close: close shm_fd failed
nv-cubb | 20:01:11.574092 nvlog.cpp:413 ERR[80 ] [NVIPC.IPC] [AERIAL_NVIPC_API_EVENT] nv_ipc_app_config_shmpool_open: primary=0, prefix=nvipc
nv-cubb | 20:01:11.574094 nvlog.cpp:413 ERR[80 ] [NVIPC.IPC] [AERIAL_NVIPC_API_EVENT] nv_ipc_app_config_get: failed: configs=(nil) item=0
nv-cubb | 20:01:11.574095 nvlog.cpp:413 ERR[80 ] [NVIPC.IPC] [AERIAL_NVIPC_API_EVENT] nv_ipc_app_config_get: failed: configs=(nil) item=1
nv-cubb | 20:01:11.574096 nvlog.cpp:413 ERR[80 ] [NVIPC.IPC] [AERIAL_NVIPC_API_EVENT] nv_ipc_app_config_get: failed: configs=(nil) item=8
nv-cubb | 20:01:11.574097 nvlog.cpp:413 ERR[80 ] [NVIPC.IPC] [AERIAL_NVIPC_API_EVENT] nv_ipc_app_config_get: failed: configs=(nil) item=9
nv-cubb | 20:01:11.574098 nvlog.cpp:404 INF[80 ] [NVIPC.DEBUG] load_debug_config: fapi_type=0 fapi_tb_loc=0 pcap_max_msg_size=0 pcap_max_data_size=0
nv-cubb | 20:01:11.574100 nvlog.cpp:404 INF[80 ] [NVIPC.SHMLOG] shmlogger_collect: save /var/log/aerial/nvipc_pcap and /dev/shm/nvipc_pcap logs to ./nvipc_pcap
nv-cubb | 20:01:11.574105 nvlog.cpp:413 ERR[80 ] [NVIPC.SHM] [AERIAL_SYSTEM_API_EVENT] ipc_shm_open: shm_open nvipc_pcap failed error -1
nv-cubb | 20:01:11.574106 nvlog.cpp:413 ERR[80 ] [NVIPC.SHM] [AERIAL_NVIPC_API_EVENT] nv_ipc_shm_open: primary=0 name=nvipc_pcap Failed
nv-cubb | 20:01:11.574106 nvlog.cpp:413 ERR[80 ] [NVIPC.SHM] [AERIAL_SYSTEM_API_EVENT] ipc_shm_close: close shm_fd failed
nv-cubb | 20:01:11.574107 nvlog.cpp:413 ERR[80 ] [NVIPC.SHMLOG] [AERIAL_NVIPC_API_EVENT] shmlogger_open: nv_ipc_shm_open failed
nv-cubb | 20:01:11.574107 nvlog.cpp:404 INF[80 ] [NVIPC.SHMLOG] shmlogger_collect: no /dev/shm/nvipc_pcap, logger may have been closed normally
nv-cubb exited with code 0
dependency failed to start: container nv-cubb exited (0)
