What is the appropriate way of changing the size of a buffer after a context has been created (between trace calls).
Example workflow:
Buffer eyeHitBuffer = _context->createBuffer(RT_BUFFER_OUTPUT);
eyeHitBuffer->setFormat(RT_FORMAT_USER);
eyeHitBuffer->setElementSize(sizeof(HitRecord));
eyeHitBuffer->setSize(WIDTH, HEIGHT);
_context[ “eyeHitBuffer” ]->set(eyeHitBuffer);
trace()
eyeHitBuffer->setSize(NEW_WIDTH, NEW_HEIGHT);
Is this sufficient or is it also necessary to use _context[ “eyeHitBuffer” ]->set(eyeHitBuffer) again?
Josh
