Hey,
I’m using Jetpack 4.5.1 TX2 and would like to change the rtc voltage for a custom carrier board to 3.3V.
I see that the max77260.c has a function for backup battery and have made the following change in the device tree.
backup-battery {
backup-battery-charging-current = <0x190>;
backup-battery-charging-voltage = <0x325aa0>;
backup-battery-output-resister = <0x64>;
status = "okay";
And here is the vdd-rtc node ldo4.
ldo4 {
regulator-name = "vdd-rtc";
regulator-always-on;
regulator-boot-on;
maxim,active-fps-source = <0x0>;
maxim,active-fps-power-up-slot = <0x1>;
maxim,active-fps-power-down-slot = <0x7>;
regulator-enable-ramp-delay = <0x1a>;
regulator-disable-ramp-delay = <0x672>;
maxim,ramp-rate-setting = <0x186a0>;
regulator-ramp-delay = <0x80e8>;
linux,phandle = <0x17a>;
phandle = <0x17a>;
If i try adding the following to ldo4 ie vdd-rtc then the jetpack does not reboot, thus crashes.
regulator-min-microvolt = <0x325aa0>;
regulator-max-microvolt = <0x325aa0>;
Also, when i run,
dmesg | grep rtc
i get the following as a response :
[ 0.565475] vdd-rtc: at 800 mV
Would like some insight on the same, Thanks
