Hi, Guys,
I’m blocked by the issue of “CHANSEL_NOMATCH”, and couldn’t capture image from mipi csi port on Orin with the below trace log.
I have follow this topic:
and Jetson/l4t/Camera BringUp - eLinux.org
As the description for the issue in this article, the 0x000003c9 should be indicated LS package’s data type is no match yuv422_8? But the data from camera is yuv422 8bit,and Orin platform set as yuv 422 8bit also.
and i config this video use csi_stream number 5 ,why there is channel:0xa0
CHANSEL_NOMATCH
bit 0 no_match
bit 1-4 CTYPE
bit 5-10 DTYPE
CTYPE:
FS = 0x8, FE = 0x1
LS = 0x4, LE = 0x2
LS_LE = 0x6, DATA = 0x9
DTYPE:
NvCsiDataType_Unspecified = 0,
NvCsiDataType_YUV420_10 = 25,
NvCsiDataType_LEG_YUV420_8 = 26,
NvCsiDataType_YUV420_8 = 24,
NvCsiDataType_YUV420CSPS_8 = 28,
NvCsiDataType_YUV420CSPS_10 = 29,
NvCsiDataType_YUV422_8 = 30,
NvCsiDataType_YUV422_10 = 31,
NvCsiDataType_RGB444 = 32,
kworker/3:2-156 [003] .... 248.630004: rtcpu_vinotify_error: tstamp:8523383170 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272748237344 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.630004: rtcpu_vinotify_event: tstamp:8523608748 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:272746880192 data:0x0000000000000025
kworker/3:2-156 [003] .... 248.630004: rtcpu_vinotify_event: tstamp:8523608898 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:272747738624 data:0x0000000000000015
kworker/3:2-156 [003] .... 248.630004: rtcpu_vinotify_event: tstamp:8523609029 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272748237344 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.685890: rtcpu_vinotify_error: tstamp:8524424855 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272781571552 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.685890: rtcpu_vinotify_event: tstamp:8524622886 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:272780214080 data:0x0000000000000025
kworker/3:2-156 [003] .... 248.685890: rtcpu_vinotify_event: tstamp:8524623017 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:272781072768 data:0x0000000000000015
kworker/3:2-156 [003] .... 248.685891: rtcpu_vinotify_event: tstamp:8524623168 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272781571552 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.685891: rtcpu_vinotify_error: tstamp:8525466541 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272814905408 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.685891: rtcpu_vinotify_event: tstamp:8525637018 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:272813548288 data:0x0000000000000025
kworker/3:2-156 [003] .... 248.685891: rtcpu_vinotify_event: tstamp:8525637169 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:272814406624 data:0x0000000000000015
kworker/3:2-156 [003] .... 248.685892: rtcpu_vinotify_event: tstamp:8525637301 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272814905408 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.742035: rtcpu_vinotify_event: tstamp:8526492459 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:272846882144 data:0x0000000000000025
kworker/3:2-156 [003] .... 248.742037: rtcpu_vinotify_event: tstamp:8526492591 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:272847740832 data:0x0000000000000015
kworker/3:2-156 [003] .... 248.742038: rtcpu_vinotify_error: tstamp:8526508242 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272848239648 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.742038: rtcpu_vinotify_event: tstamp:8526820200 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272848239648 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.742039: rtcpu_vinotify_error: tstamp:8527549919 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272881573504 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.798005: rtcpu_vinotify_event: tstamp:8527834334 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:272880216352 data:0x0000000000000025
kworker/3:2-156 [003] .... 248.798007: rtcpu_vinotify_event: tstamp:8527834482 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:272881074688 data:0x0000000000000015
kworker/3:2-156 [003] .... 248.798007: rtcpu_vinotify_event: tstamp:8527834610 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272881573504 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.798008: rtcpu_vinotify_error: tstamp:8528591601 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272914907360 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.798008: rtcpu_vinotify_event: tstamp:8528848469 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:272913550176 data:0x0000000000000025
kworker/3:2-156 [003] .... 248.798009: rtcpu_vinotify_event: tstamp:8528848599 cch:0 vi:1 tag:FS channel:0x02 frame:0 vi_tstamp:272914408928 data:0x0000000000000015
kworker/3:2-156 [003] .... 248.798009: rtcpu_vinotify_event: tstamp:8528848749 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272914907360 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.853918: rtcpu_vinotify_error: tstamp:8529633292 cch:0 vi:1 tag:CHANSEL_NOMATCH channel:0xa0 frame:0 vi_tstamp:272948241568 data:0x00000000000003c9
kworker/3:2-156 [003] .... 248.853922: rtcpu_vinotify_event: tstamp:8529862612 cch:0 vi:1 tag:FE channel:0x02 frame:0 vi_tstamp:272946884096 data:0x0000000000000025
At the same time, the syslog as below:
[ 75.025843] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
[ 75.270685] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 256
