CHANSEL_NOMATCH error
I cann’t catch the data from my gmsl camera og02b10.
Here is the kernal log:
[  125.808494] og02b10 9-0017: pcai : og02b10_power_on: power on
[  125.819309] og02b10 9-0017: pcai : og02b10_set_mode, mode=0
[  125.819317] og02b10 9-0017: pcai : og02b10_write_table
[  125.819325] og02b10 9-0017: pcai : og02b10 (0x0103)->0x01
[  125.819330] og02b10 9-0017: pcai : og02b10 (0x0100)->0x00
[  125.819335] og02b10 9-0017: pcai : og02b10 (0x010c)->0x02
[  125.819339] og02b10 9-0017: pcai : og02b10 (0x010b)->0x01
[  125.819343] og02b10 9-0017: pcai : og02b10  more...
[  125.961651] og02b10 9-0017: pcai : og02b10_start_streaming
[  125.961664] max9295 9-0042: pcai : 9295 setup streaming - enter
[  125.961697] max9295 9-0042: pcai : 9295 port=B
[  125.964618] max9295 9-0042: pcai : 9295: cnt=0,stream_type=RAW10
[  125.965059] max9295 9-0042: pcai : 9295: routing data_type=0x2b to PipelineX, with stream_id=0
[  125.965069] max9295 9-0042: pcai : 9295 start pipeline...:
[  125.966254] max9295 9-0042: pcai : 9295 setup streaming - exit
[  125.966264] max9296 9-0048: pcai : 9296 setup streaming - enter
[  125.966273] max9296 9-0048: pcai : 9296: num_streams=1
[  125.966280] max9296 9-0048: pcai : 9296: 0 stream_type is RAW10
[  125.966289] max9296 9-0048: pcai : rx_0 receive stream_id=0, datatype=0x2b, vc=0
[  125.970888] max9296 9-0048: pcai : 9296 num_csi_lanes=2
[  125.972358] max9296 9-0048: pcai : 9296 setup streaming - exit
[  125.972373] max9296 9-0048: pcai : 9296 start streaming - enter
[  125.972397] max9296 9-0048: pcai : trigger skew calibration
[  125.975255] max9296 9-0048: pcai : 9296 start streaming - exit
[  125.975266] og02b10 9-0017: pcai : og02b10_write_table
[  125.975274] og02b10 9-0017: pcai : og02b10 (0x0100)->0x01
[  125.996219] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
[  126.030312] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
[  126.065879] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
[  126.101478] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 0, flags: 0, err_data 512
[  128.910570] og02b10 9-0017: pcai : og02b10_stop_streaming
[  128.910599] max9296 9-0048: pcai : 9296 stop streaming - enter
[  128.911210] max9296 9-0048: pcai : 9296 stop streaming - exit
[  128.911221] og02b10 9-0017: pcai : og02b10_write_table
[  128.911268] og02b10 9-0017: pcai : og02b10 (0x0100)->0x00
[  128.967776] og02b10 9-0017: pcai : og02b10_power_off: power off
I boost the clocks to try and it still failed.
root@tegra-ubuntu:/home/pcai# echo 1 > /sys/kernel/debug/bpmp/debug/clk/vi/mrq_rate_locked
root@tegra-ubuntu:/home/pcai# echo 1 > /sys/kernel/debug/bpmp/debug/clk/isp/mrq_rate_locked
root@tegra-ubuntu:/home/pcai# echo 1 > /sys/kernel/debug/bpmp/debug/clk/nvcsi/mrq_rate_locked
root@tegra-ubuntu:/home/pcai# echo 1 > /sys/kernel/debug/bpmp/debug/clk/emc/mrq_rate_locked
root@tegra-ubuntu:/home/pcai# cat /sys/kernel/debug/bpmp/debug/clk/vi/max_rate |tee /sys/kernel/debug/bpmp/debug/clk/vi/rate
460800000
root@tegra-ubuntu:/home/pcai# cat /sys/kernel/debug/bpmp/debug/clk/isp/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/isp/rate
576000000
root@tegra-ubuntu:/home/pcai# cat /sys/kernel/debug/bpmp/debug/clk/nvcsi/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/nvcsi/rate
314000000
root@tegra-ubuntu:/home/pcai# cat /sys/kernel/debug/bpmp/debug/clk/emc/max_rate | tee /sys/kernel/debug/bpmp/debug/clk/emc/rate
1866000000
root@tegra-ubuntu:/home/pcai# ./openRecord.sh
root@tegra-ubuntu:/home/pcai# ./readRecord.sh
# tracer: nop
# entries-in-buffer/entries-written: 259/259   #P:4
#                                _-----=> irqs-off
#                               / _----=> need-resched
#                              | / _---=> hardirq/softirq
#                              || / _--=> preempt-depth
#                              ||| /     delay
#           TASK-PID     CPU#  ||||   TIMESTAMP  FUNCTION
        v4l2-ctl-6997    [001] ....  1141.501303: tegra_channel_open: vi-output, og02b10 9-0017
        v4l2-ctl-6997    [001] ....  1141.508286: tegra_channel_set_power: og02b10 9-0017 : 0x1
        v4l2-ctl-6997    [001] ....  1141.508299: camera_common_s_power: status : 0x1
        v4l2-ctl-6997    [001] ....  1141.508329: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-6997    [001] ....  1141.508331: csi_s_power: enable : 0x1
        v4l2-ctl-6997    [001] ....  1141.508824: tegra_channel_capture_setup: vnc_id 0 W 1600 H 1300 fmt c4
        v4l2-ctl-6997    [000] ....  1141.509750: tegra_channel_set_stream: enable : 0x1
        v4l2-ctl-6997    [000] ....  1141.511006: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x1
        v4l2-ctl-6997    [000] ....  1141.511009: csi_s_stream: enable : 0x1
        v4l2-ctl-6997    [000] ....  1141.511406: tegra_channel_set_stream: og02b10 9-0017 : 0x1
     kworker/3:2-105     [003] ....  1141.564088: rtcpu_vinotify_event: tstamp:36339423074 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1162851181088 data:0xcd9ce50010000000
     kworker/3:2-105     [003] ....  1141.564092: rtcpu_vinotify_event: tstamp:36339423235 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1162851192864 data:0x0000000031000001
     kworker/3:2-105     [003] ....  1141.564093: rtcpu_vinotify_event: tstamp:36339423397 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1162851239008 data:0xcd9ce20010000000
     kworker/3:2-105     [003] ....  1141.564094: rtcpu_vinotify_event: tstamp:36339423539 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1162851250944 data:0x0000000031000002
     kworker/3:2-105     [003] ....  1141.680068: rtcpu_nvcsi_intr: tstamp:36343587241 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x01c00000
     kworker/3:2-105     [003] ....  1141.736038: rtcpu_vinotify_event: tstamp:36344509371 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163017654720 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1141.736040: rtcpu_vinotify_event: tstamp:36344509537 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1163017654752 data:0x0000000800000000
     kworker/3:2-105     [003] ....  1141.736041: rtcpu_vinotify_event: tstamp:36344509699 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1163017657760 data:0x0000000000000001
     kworker/3:2-105     [003] ....  1141.736042: rtcpu_vinotify_event: tstamp:36344509843 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1163017665664 data:0x0000000008020001
     kworker/3:2-105     [003] ....  1141.736043: rtcpu_vinotify_event: tstamp:36344510004 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1163017659040 data:0x0000000000000200
     kworker/3:2-105     [003] ....  1141.736043: rtcpu_vinotify_event: tstamp:36344510144 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1163017683840 data:0x0000000001020001
     kworker/3:2-105     [003] ....  1141.736044: rtcpu_vinotify_event: tstamp:36344848462 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163032836352 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1141.736044: rtcpu_vinotify_event: tstamp:36344848606 cch:0 vi:0 tag:CHANSEL_SHORT_FRAME channel:0x01 frame:0 vi_tstamp:1163032836384 data:0x0000200001000000
     kworker/3:2-105     [003] ....  1141.736045: rtcpu_vinotify_event: tstamp:36344848768 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1163032836384 data:0x0000000800000000
     kworker/3:2-105     [003] ....  1141.736046: rtcpu_vinotify_event: tstamp:36344848908 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1163032874560 data:0xcd9ce50010000000
     kworker/3:2-105     [003] ....  1141.736046: rtcpu_vinotify_event: tstamp:36344849066 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1163032886464 data:0x0000000031000003
     kworker/3:2-105     [003] ....  1141.736047: rtcpu_vinotify_event: tstamp:36345375630 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163051986432 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1141.736051: rtcpu_vinotify_event: tstamp:36345696100 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1163051986464 data:0x0000000800000000
     kworker/3:2-105     [003] ....  1141.736052: rtcpu_vinotify_event: tstamp:36345696250 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1163052107168 data:0x0000000000000001
     kworker/3:2-105     [003] ....  1141.736073: rtcpu_vinotify_event: tstamp:36345696416 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1163052109888 data:0x0000000008020002
     kworker/3:2-105     [003] ....  1141.736074: rtcpu_vinotify_event: tstamp:36345696556 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1163052111712 data:0x0000000000000200
     kworker/3:2-105     [003] ....  1141.736074: rtcpu_vinotify_event: tstamp:36345696714 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1163052128576 data:0x0000000001020002
     kworker/3:2-105     [003] ....  1141.736078: rtcpu_vinotify_event: tstamp:36346035123 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1163068428640 data:0x0000000005130202
     kworker/3:2-105     [003] ....  1141.736078: rtcpu_vinotify_event: tstamp:36346035294 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1163068429088 data:0x0000000000000000
     kworker/3:2-105     [003] ....  1141.736079: rtcpu_vinotify_event: tstamp:36346035434 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163068429216 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1141.736080: rtcpu_vinotify_event: tstamp:36346035598 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1163068429248 data:0x0000000800000000
     kworker/3:2-105     [003] ....  1141.736080: rtcpu_vinotify_event: tstamp:36346035739 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1163068472064 data:0xcd9ce20010000000
     kworker/3:2-105     [003] ....  1141.736081: rtcpu_vinotify_event: tstamp:36346035897 cch:0 vi:0 tag:VIFALC_TDSTATE channel:0x23 frame:0 vi_tstamp:1163068484032 data:0x0000000031000004
     kworker/3:2-105     [003] ....  1141.792059: rtcpu_vinotify_event: tstamp:36346494328 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163087579712 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1141.792062: rtcpu_vinotify_event: tstamp:36346494502 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1163087579744 data:0x0000000800000000
     kworker/3:2-105     [003] ....  1141.792063: rtcpu_vinotify_event: tstamp:36346494646 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1163087700544 data:0x0000000000000001
     kworker/3:2-105     [003] ....  1141.792064: rtcpu_vinotify_event: tstamp:36346494806 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1163087703264 data:0x0000000008020003
     kworker/3:2-105     [003] ....  1141.792065: rtcpu_vinotify_event: tstamp:36346494948 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1163087705152 data:0x0000000000000200
     kworker/3:2-105     [003] ....  1141.792066: rtcpu_vinotify_event: tstamp:36346815272 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1163087724160 data:0x0000000001020003
     kworker/3:2-105     [003] ....  1141.792067: rtcpu_vinotify_event: tstamp:36347154227 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1163104022080 data:0x0000000005130202
     kworker/3:2-105     [003] ....  1141.792068: rtcpu_vinotify_event: tstamp:36347154391 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1163104022528 data:0x0000000000000000
     kworker/3:2-105     [003] ....  1141.792069: rtcpu_vinotify_event: tstamp:36347154532 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163104022688 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1141.792070: rtcpu_vinotify_event: tstamp:36347154694 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1163104022720 data:0x0000000800000000
     kworker/3:2-105     [003] ....  1141.792072: rtcpu_vinotify_event: tstamp:36347832325 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163123172640 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1141.792073: rtcpu_vinotify_event: tstamp:36347832496 cch:0 vi:0 tag:ATOMP_FS channel:0x00 frame:0 vi_tstamp:1163123172672 data:0x0000000800000000
     kworker/3:2-105     [003] ....  1141.792074: rtcpu_vinotify_event: tstamp:36347832641 cch:0 vi:0 tag:CHANSEL_PXL_SOF channel:0x23 frame:0 vi_tstamp:1163123293408 data:0x0000000000000001
     kworker/3:2-105     [003] ....  1141.792075: rtcpu_vinotify_event: tstamp:36347832801 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1163123296128 data:0x0000000008020004
     kworker/3:2-105     [003] ....  1141.792076: rtcpu_vinotify_event: tstamp:36347832941 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1163123297984 data:0x0000000000000200
     kworker/3:2-105     [003] ....  1141.792077: rtcpu_vinotify_event: tstamp:36347833099 cch:0 vi:0 tag:VIFALC_ACTIONLST channel:0x23 frame:0 vi_tstamp:1163123314816 data:0x0000000001020004
     kworker/3:2-105     [003] ....  1141.848043: rtcpu_vinotify_event: tstamp:36348171499 cch:0 vi:0 tag:CHANSEL_FAULT channel:0x23 frame:0 vi_tstamp:1163139616128 data:0x0000000005130202
     kworker/3:2-105     [003] ....  1141.848045: rtcpu_vinotify_event: tstamp:36348171666 cch:0 vi:0 tag:ATOMP_FRAME_DONE channel:0x23 frame:0 vi_tstamp:1163139616544 data:0x0000000000000000
     kworker/3:2-105     [003] ....  1141.848046: rtcpu_vinotify_event: tstamp:36348171808 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163139616704 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1141.848047: rtcpu_vinotify_event: tstamp:36348171975 cch:0 vi:0 tag:ATOMP_FE channel:0x00 frame:0 vi_tstamp:1163139616736 data:0x0000000800000000
     kworker/3:2-105     [003] ....  1141.848048: rtcpu_vinotify_event: tstamp:36348712344 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163158766752 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1141.848050: rtcpu_vinotify_error: tstamp:36348716292 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163158886176 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1141.848051: rtcpu_vinotify_event: tstamp:36349019105 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163158886176 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1141.848052: rtcpu_vinotify_event: tstamp:36349358198 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163175209760 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1141.904025: rtcpu_vinotify_error: tstamp:36349828548 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163194478144 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1141.904028: rtcpu_vinotify_event: tstamp:36350036416 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163194360096 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1141.904029: rtcpu_vinotify_event: tstamp:36350036560 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163194478144 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1141.904030: rtcpu_vinotify_event: tstamp:36350375511 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163210803904 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1141.904031: rtcpu_vinotify_error: tstamp:36350940868 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163230072512 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1141.904031: rtcpu_vinotify_event: tstamp:36351053724 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163229955232 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1141.904032: rtcpu_vinotify_event: tstamp:36351053889 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163230072512 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1141.960002: rtcpu_vinotify_event: tstamp:36351731870 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163246397152 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1141.960004: rtcpu_vinotify_error: tstamp:36352053150 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163265665632 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1141.960005: rtcpu_vinotify_event: tstamp:36352071035 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163265547168 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1141.960005: rtcpu_vinotify_event: tstamp:36352071179 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163265665632 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1141.960006: rtcpu_vinotify_event: tstamp:36352749187 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163281988640 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1141.960006: rtcpu_vinotify_error: tstamp:36353165433 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163301258560 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.016002: rtcpu_vinotify_event: tstamp:36353427395 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163301138464 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.016004: rtcpu_vinotify_event: tstamp:36353427561 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163301258560 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.016024: rtcpu_vinotify_event: tstamp:36353766507 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163317581024 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.016025: rtcpu_vinotify_error: tstamp:36354277778 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163336852608 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.016026: rtcpu_vinotify_event: tstamp:36354278418 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163336731840 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.016026: rtcpu_vinotify_event: tstamp:36354278559 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163336852608 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.016027: rtcpu_vinotify_event: tstamp:36354817754 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163353175296 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.071997: rtcpu_vinotify_error: tstamp:36355390069 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163372446816 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.071999: rtcpu_vinotify_event: tstamp:36355495699 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163372326080 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.072000: rtcpu_vinotify_event: tstamp:36355495862 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163372446816 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.072001: rtcpu_vinotify_event: tstamp:36356174100 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163388768704 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.072001: rtcpu_vinotify_error: tstamp:36356502325 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163408038976 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.072002: rtcpu_vinotify_event: tstamp:36356513008 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163407919136 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.072003: rtcpu_vinotify_event: tstamp:36356513152 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163408038976 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.127986: rtcpu_vinotify_event: tstamp:36357191136 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163424363072 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.128017: rtcpu_vinotify_error: tstamp:36357614572 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163443631008 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.128018: rtcpu_vinotify_event: tstamp:36357869356 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163443512896 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.128019: rtcpu_vinotify_event: tstamp:36357869520 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163443631008 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.128020: rtcpu_vinotify_event: tstamp:36358208453 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163459956160 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.183982: rtcpu_vinotify_error: tstamp:36358726871 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163479224480 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.183984: rtcpu_vinotify_event: tstamp:36358886679 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163479107008 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.183985: rtcpu_vinotify_event: tstamp:36358886826 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163479224480 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.183985: rtcpu_vinotify_event: tstamp:36359564812 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163495548640 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.183986: rtcpu_vinotify_error: tstamp:36359839170 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163514818144 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.183987: rtcpu_vinotify_event: tstamp:36359903982 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163514698784 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.183987: rtcpu_vinotify_event: tstamp:36359904144 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163514818144 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.239973: rtcpu_vinotify_event: tstamp:36360349042 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163531140800 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.239974: rtcpu_vinotify_error: tstamp:36360951467 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163550411616 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.239993: rtcpu_vinotify_event: tstamp:36360955131 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163550290784 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.239993: rtcpu_vinotify_event: tstamp:36360955274 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163550411616 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.239994: rtcpu_vinotify_event: tstamp:36361633270 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163566733408 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.295954: rtcpu_vinotify_error: tstamp:36362063759 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163586004992 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.295956: rtcpu_vinotify_event: tstamp:36362311482 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163585884224 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.295957: rtcpu_vinotify_event: tstamp:36362311647 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163586004992 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.295958: rtcpu_vinotify_event: tstamp:36362650589 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163602327456 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.295959: rtcpu_vinotify_error: tstamp:36363176027 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163621597440 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.295960: rtcpu_vinotify_event: tstamp:36363328802 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163621478016 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.295960: rtcpu_vinotify_event: tstamp:36363328947 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163621597440 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.351962: rtcpu_vinotify_event: tstamp:36364006945 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163637922368 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.351964: rtcpu_vinotify_error: tstamp:36364288292 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163657190048 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.351965: rtcpu_vinotify_event: tstamp:36364346118 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163657072544 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.351983: rtcpu_vinotify_event: tstamp:36364346281 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163657190048 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.351984: rtcpu_vinotify_event: tstamp:36365024258 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163673516384 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.351985: rtcpu_vinotify_error: tstamp:36365400612 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163692784480 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.407943: rtcpu_vinotify_event: tstamp:36365702453 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163692666496 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.407945: rtcpu_vinotify_event: tstamp:36365702601 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163692784480 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.407946: rtcpu_vinotify_event: tstamp:36366041561 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163709107648 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.407946: rtcpu_vinotify_event: tstamp:36366508951 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163728258048 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.407947: rtcpu_vinotify_error: tstamp:36366512908 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163728378016 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.407948: rtcpu_vinotify_event: tstamp:36366821246 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163728378016 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.407949: rtcpu_vinotify_event: tstamp:36367160337 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163744701792 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.463946: rtcpu_vinotify_error: tstamp:36367625262 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163763973024 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.463947: rtcpu_vinotify_event: tstamp:36367838563 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163763852288 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.463968: rtcpu_vinotify_event: tstamp:36367838711 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163763973024 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.463968: rtcpu_vinotify_event: tstamp:36368177658 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163780295680 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.463969: rtcpu_vinotify_error: tstamp:36368737597 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163799567680 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.463970: rtcpu_vinotify_event: tstamp:36368855871 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163799447104 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.463970: rtcpu_vinotify_event: tstamp:36368856050 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163799567680 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.519927: rtcpu_vinotify_event: tstamp:36369533999 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163815890208 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.519929: rtcpu_vinotify_error: tstamp:36369849830 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163835159264 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.519929: rtcpu_vinotify_event: tstamp:36369873183 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163835040768 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.519930: rtcpu_vinotify_event: tstamp:36369873329 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163835159264 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.519931: rtcpu_vinotify_event: tstamp:36370551324 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163851484384 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.575932: rtcpu_vinotify_error: tstamp:36370962102 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163870751872 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.575934: rtcpu_vinotify_event: tstamp:36371229531 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163870634336 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.575950: rtcpu_vinotify_event: tstamp:36371229733 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163870751872 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.575951: rtcpu_vinotify_event: tstamp:36371568637 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163887075904 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.575952: rtcpu_vinotify_error: tstamp:36372074424 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163906345184 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.575953: rtcpu_vinotify_event: tstamp:36372075061 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163906225600 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.575954: rtcpu_vinotify_event: tstamp:36372075204 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163906345184 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.631924: rtcpu_vinotify_event: tstamp:36372585805 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163922666656 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.631928: rtcpu_vinotify_error: tstamp:36373186621 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163941936544 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.631929: rtcpu_vinotify_event: tstamp:36373264011 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163941815776 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.631930: rtcpu_vinotify_event: tstamp:36373264175 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163941936544 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.631930: rtcpu_vinotify_event: tstamp:36373942142 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163958258528 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.687912: rtcpu_vinotify_error: tstamp:36374298877 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163977528928 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.687915: rtcpu_vinotify_event: tstamp:36374620354 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1163977408192 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.687916: rtcpu_vinotify_event: tstamp:36374620499 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1163977528928 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.687917: rtcpu_vinotify_event: tstamp:36374959458 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1163993850592 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.687918: rtcpu_vinotify_error: tstamp:36375411062 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164013118720 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.687918: rtcpu_vinotify_event: tstamp:36375637675 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164013000608 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.687919: rtcpu_vinotify_event: tstamp:36375637837 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164013118720 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.743912: rtcpu_vinotify_event: tstamp:36375976775 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164029443104 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.743914: rtcpu_vinotify_error: tstamp:36376523309 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164048710592 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.743936: rtcpu_vinotify_event: tstamp:36376654996 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164048592608 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.743937: rtcpu_vinotify_event: tstamp:36376655141 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164048710592 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.743938: rtcpu_vinotify_event: tstamp:36377333129 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164065032928 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.743939: rtcpu_vinotify_error: tstamp:36377635576 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164084303104 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.799895: rtcpu_vinotify_event: tstamp:36377672028 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164084182336 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.799896: rtcpu_vinotify_event: tstamp:36377672193 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164084303104 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.799897: rtcpu_vinotify_event: tstamp:36378145416 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164100624864 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.799898: rtcpu_vinotify_error: tstamp:36378747789 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164119894144 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.799899: rtcpu_vinotify_event: tstamp:36378757273 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164119773408 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.799900: rtcpu_vinotify_event: tstamp:36378757414 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164119894144 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.855894: rtcpu_vinotify_event: tstamp:36379435420 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164136215584 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.855896: rtcpu_vinotify_error: tstamp:36379859981 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164155484032 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.855918: rtcpu_vinotify_event: tstamp:36380113637 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164155365792 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.855919: rtcpu_vinotify_event: tstamp:36380113801 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164155484032 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.855920: rtcpu_vinotify_event: tstamp:36380452744 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164171808352 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.855920: rtcpu_vinotify_error: tstamp:36380972198 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164191075040 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.855921: rtcpu_vinotify_event: tstamp:36381130958 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164190956544 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.855922: rtcpu_vinotify_event: tstamp:36381131104 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164191075040 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.911913: rtcpu_vinotify_event: tstamp:36381809105 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164207396768 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.911915: rtcpu_vinotify_error: tstamp:36382084450 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164226667072 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.911917: rtcpu_vinotify_event: tstamp:36382148002 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164226546272 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.911917: rtcpu_vinotify_event: tstamp:36382148164 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164226667072 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.911918: rtcpu_vinotify_event: tstamp:36382826148 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164242988288 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.967886: rtcpu_vinotify_error: tstamp:36383196657 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164262257888 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.967888: rtcpu_vinotify_event: tstamp:36383504349 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164262138304 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.967888: rtcpu_vinotify_event: tstamp:36383504493 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164262257888 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.967889: rtcpu_vinotify_event: tstamp:36383843460 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164278580768 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1142.967890: rtcpu_vinotify_event: tstamp:36384304926 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164297729344 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1142.967890: rtcpu_vinotify_error: tstamp:36384308820 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164297847104 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1142.967891: rtcpu_vinotify_event: tstamp:36384623436 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164297847104 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.023859: rtcpu_vinotify_event: tstamp:36384962530 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164314169088 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.023860: rtcpu_vinotify_error: tstamp:36385421081 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164333439232 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.023861: rtcpu_vinotify_event: tstamp:36385640744 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164333318432 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.023862: rtcpu_vinotify_event: tstamp:36385640891 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164333439232 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.023862: rtcpu_vinotify_event: tstamp:36385979883 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164349761024 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.079847: rtcpu_vinotify_error: tstamp:36386533299 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164369030176 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.079849: rtcpu_vinotify_event: tstamp:36386658055 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164368911296 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.079850: rtcpu_vinotify_event: tstamp:36386658218 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164369030176 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.079872: rtcpu_vinotify_event: tstamp:36387336185 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164385352704 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.079872: rtcpu_vinotify_error: tstamp:36387645460 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164404619456 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.079873: rtcpu_vinotify_event: tstamp:36387675092 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164404500544 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.079874: rtcpu_vinotify_event: tstamp:36387675235 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164404619456 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.135841: rtcpu_vinotify_event: tstamp:36388353514 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164420942240 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.135842: rtcpu_vinotify_error: tstamp:36388757741 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164440212416 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.135843: rtcpu_vinotify_event: tstamp:36389031447 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164440091680 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.135844: rtcpu_vinotify_event: tstamp:36389031613 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164440212416 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.135844: rtcpu_vinotify_event: tstamp:36389370552 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164456534080 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.135845: rtcpu_vinotify_error: tstamp:36389869933 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164475801504 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.135846: rtcpu_vinotify_event: tstamp:36389870573 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164475684096 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.135846: rtcpu_vinotify_event: tstamp:36389870717 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164475801504 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.191848: rtcpu_vinotify_event: tstamp:36390387989 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164492123392 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.191849: rtcpu_vinotify_error: tstamp:36390982195 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164511394944 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.191850: rtcpu_vinotify_event: tstamp:36391066190 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164511274144 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.191851: rtcpu_vinotify_event: tstamp:36391066354 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164511394944 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.247829: rtcpu_vinotify_event: tstamp:36391744328 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164527717504 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.247830: rtcpu_vinotify_error: tstamp:36392094392 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164546985152 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.247831: rtcpu_vinotify_event: tstamp:36392422543 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164546867680 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.247831: rtcpu_vinotify_event: tstamp:36392422691 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164546985152 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.247832: rtcpu_vinotify_event: tstamp:36392761639 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164563307712 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.247833: rtcpu_vinotify_error: tstamp:36393206696 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164582578880 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.303833: rtcpu_vinotify_event: tstamp:36393439585 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164582458112 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.303835: rtcpu_vinotify_event: tstamp:36393439752 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164582578880 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.303836: rtcpu_vinotify_event: tstamp:36393778685 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164598901024 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.303837: rtcpu_vinotify_error: tstamp:36394318873 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164618168608 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.303837: rtcpu_vinotify_event: tstamp:36394456913 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164618049120 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.303838: rtcpu_vinotify_event: tstamp:36394457059 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164618168608 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.303839: rtcpu_vinotify_event: tstamp:36395135049 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164634490592 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.359832: rtcpu_vinotify_error: tstamp:36395431058 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164653758720 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.359833: rtcpu_vinotify_event: tstamp:36395474212 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164653640352 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.359834: rtcpu_vinotify_event: tstamp:36395474376 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164653758720 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.359835: rtcpu_vinotify_event: tstamp:36395940932 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164670081376 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.359835: rtcpu_vinotify_error: tstamp:36396543357 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164689352384 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.359836: rtcpu_vinotify_event: tstamp:36396559178 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164689231584 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.359837: rtcpu_vinotify_event: tstamp:36396559321 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164689352384 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.415806: rtcpu_vinotify_event: tstamp:36397237597 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164705674592 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.415807: rtcpu_vinotify_error: tstamp:36397655549 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164724942208 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.415808: rtcpu_vinotify_event: tstamp:36397915539 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164724822560 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.415808: rtcpu_vinotify_event: tstamp:36397915704 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164724942208 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.415809: rtcpu_vinotify_event: tstamp:36398254634 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164741264608 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.471811: rtcpu_vinotify_error: tstamp:36398767737 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164760532256 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.471812: rtcpu_vinotify_event: tstamp:36398932848 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164760414944 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.471813: rtcpu_vinotify_event: tstamp:36398932994 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164760532256 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.471814: rtcpu_vinotify_event: tstamp:36399610986 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164776857760 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.471814: rtcpu_vinotify_error: tstamp:36399880075 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164796127072 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.471815: rtcpu_vinotify_event: tstamp:36399950160 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164796007872 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.471838: rtcpu_vinotify_event: tstamp:36399950324 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164796127072 data:0x0000000000000569
        v4l2-ctl-6997    [003] ....  1143.508409: tegra_channel_close: vi-output, og02b10 9-0017
        v4l2-ctl-6997    [003] ....  1143.508504: tegra_channel_set_stream: enable : 0x0
        v4l2-ctl-6997    [003] ....  1143.508506: tegra_channel_set_stream: og02b10 9-0017 : 0x0
     kworker/3:2-105     [003] ....  1143.527813: rtcpu_vinotify_event: tstamp:36400628309 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164812448352 data:0x0000000000000020
     kworker/3:2-105     [003] ....  1143.527816: rtcpu_vinotify_error: tstamp:36400992290 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164831718112 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.527818: rtcpu_vinotify_event: tstamp:36401306511 cch:0 vi:0 tag:FS channel:0x00 frame:0 vi_tstamp:1164831597344 data:0x0000000000000010
     kworker/3:2-105     [003] ....  1143.527819: rtcpu_vinotify_event: tstamp:36401306657 cch:0 vi:0 tag:CHANSEL_NOMATCH channel:0x01 frame:0 vi_tstamp:1164831718112 data:0x0000000000000569
     kworker/3:2-105     [003] ....  1143.527820: rtcpu_vinotify_event: tstamp:36401645619 cch:0 vi:0 tag:FE channel:0x00 frame:0 vi_tstamp:1164848040864 data:0x0000000000000020
        v4l2-ctl-6997    [003] ....  1143.561866: tegra_channel_set_stream: 13e10000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-6997    [003] ....  1143.561870: csi_s_stream: enable : 0x0
        v4l2-ctl-6997    [003] ....  1143.564083: tegra_channel_set_power: og02b10 9-0017 : 0x0
        v4l2-ctl-6997    [003] ....  1143.564102: camera_common_s_power: status : 0x0
        v4l2-ctl-6997    [003] ....  1143.564127: tegra_channel_set_power: 13e10000.host1x:nvcsi@15a00000- : 0x0
        v4l2-ctl-6997    [003] ....  1143.564129: csi_s_power: enable : 0x0
Any guidance and help would be greatly appreciated.Thanks!
According to the information provided by the reference document Jetson/l4t/Camera BringUp
CHANSEL_NOMATCH
   bit 0        no_match
   bit 1-4    CTYPE
   bit 5-10  DTYPE
   CTYPE:
       FS    = 0x8, FE   = 0x1
       LS    = 0x4, LE   = 0x2
       LS_LE = 0x6, DATA = 0x9
   DTYPE:
       NvCsiDataType_Unspecified             = 0,
       NvCsiDataType_YUV420_10               = 25,
       NvCsiDataType_LEG_YUV420_8            = 26,
       NvCsiDataType_YUV420_8                = 24,
       NvCsiDataType_YUV420CSPS_8            = 28,
       NvCsiDataType_YUV420CSPS_10           = 29,
       NvCsiDataType_YUV422_8                = 30,
       NvCsiDataType_YUV422_10               = 31,
       NvCsiDataType_RGB444                  = 32,
       NvCsiDataType_RGB555                  = 33,
       NvCsiDataType_RGB565                  = 34,
       NvCsiDataType_RGB666                  = 35,
       NvCsiDataType_RGB888                  = 36,
       NvCsiDataType_RAW6                    = 40,
       NvCsiDataType_RAW7                    = 41,
       NvCsiDataType_RAW8                    = 42,
       NvCsiDataType_RAW10                   = 43,
       NvCsiDataType_RAW12                   = 44,
       NvCsiDataType_RAW14                   = 45,
       NvCsiDataType_RAW16                   = 46,
       NvCsiDataType_RAW20                   = 47,
       NvCsiDataType_User_1                  = 48,
       NvCsiDataType_User_2                  = 49,
       NvCsiDataType_User_3                  = 50,
       NvCsiDataType_User_4                  = 51,
       NvCsiDataType_User_5                  = 52,
       NvCsiDataType_User_6                  = 53,
       NvCsiDataType_User_7                  = 54,
       NvCsiDataType_User_8                  = 55,
       NvCsiDataType_Unknown                 = 64,
According to the error data value: 0x0000000000000569(0b010101101001)
  • The value of no_match is 1: Indicates that a mismatch error did occur
  • The value of CTYPE is 4: corresponds to LS (Line Start), which means that this mismatch error is related to the start of a line of data
  • The value of DTYPE is 43: corresponds to RAW10, which is consistent with the data type from my sensor. There is no problem with this item.
Solution:
  1. Configure embedded_metadata_height = “0”;
  2. Ensure that the sensor has no metadata configured
  3. Remove the metadata configuration of serdes and deserdes
This is resolved and kept for record.
