I am trying to compile the following code (subset of a larger program) that does not contain any cuda/openacc statements
module nls_var
character(32),parameter,dimension(3)::tags_Tvel_corr=(/
& "$\overline{\rho u_1^{'}T^{'}}$ "
& ,"$\overline{\rho u_2^{'}T^{'}}$ "
& ,"$\overline{\rho u_3^{'}T^{'}}$ "
end module
with
pgfortran -Mcuda=cuda8.0 -c test_issue.f
and get the following compiler error:
nvvmCompileProgram error: 9.
Error: /tmp/pgaccK5ySq03eYCY.gpu (10, 73): parse constant expression type mismatch
PGF90-F-0155-Compiler failed to translate accelerator region (see -Minfo messages): Device compiler exited with error status code (test_issue.f: 1)
PGF90/x86-64 Linux 16.10-0: compilation aborted
After the compilation the temp file is gone so I don’t know what it contains.
The error appears both on a CRAY as well as on my local system. There is no additional output on the terminal. If I leave -Mcuda=cuda8.0 out the compilation works. Also removing the parameter statement in the code solves the issue.
Is this a bug or am I violating the Fortran standard?
