ChatRTX using a networked drive as a dataset
I’m attempting to use ChatRTX 0.3 with a data set on a separate PC. I have attempted to use both shared folder function from Windows and a networked drive. Both give an error and prevent restarting of ChatRTX. Devices are connected by wired Network. Works fine on local storage. Is this a limitation of the program or is there some sort of coding I need to do to get this to work?
does the computer that has chatRTX installed has access to this network drive?
Yes, It has access, I have been able to browse the files from the chatRTX PC in Windows Explorer. The problem comes after selecting the network drive as the dataset for ChatRTX.
