Checking for NaN and -1.#IND
Hey guys,
I have a program im working with and currently have up and running.
However the results I am getting back are either incredibly small, NaN, or -1.#IND.
I know the results I SHOULD be getting since we have a VB version of the program running with the same data.
I can’t seem to track down where the error is coming from exactly so I want to put in checks to catch where the NaN/-1.#IND is coming from.
I’ve seen suggestions to use isnan() but that is not recognized within a kernel. Could someone suggest a good way to do this within a kernel?
Thanks a lot!
isnan should work in kernels and is what you want, can you show your code?
Hmm that’s odd, I should only need to #include math.h right?
Maybe I did something wrong then, I will check again.
My code is pretty large out of where it could be going wrong. But So far I have tracked the error down to one function.
__device__ double getInteraction(int isoN, int run, double xtemp, double ytemp, double ztemp, double thxt, double thyt, double thzt,
									double Isomer1_arr[100][17], double Isomer2_arr[100][17], double SP_arr[100][17], double Shift_arr[100][17]){
//rotation variables
double cx, cy, cz;									//cos xyz
double sx, sy, sz;									//sin xyz
double xt, yt, zt;									//temp/prime
double R11, R12, R13, R21, R22, R23, R31, R32, R33;	//temp values
double thx, thy, thz;								//shift angle values
double xshift, yshift, zshift;						//x,y,z shift values
int iMax, jMax;
double x, y, z;										//holds values from isomer 1 or 2
double temp_arr[100][17];							//temp array (replaces sheet 5) 100 rows of 17 columns
//energy variables
double xs, ys, zs;									//coordinates of SP, reuse x,y,z from before for coord of isomers
double r, r2;										//Inter atome (mol-SP) distance and square of same
double Eq, Eqt;										//electrostatic energy
double Enb, Enbt;									//non-bonded energy
double A, B, rStar, epsilon;						//non-bonded parameters
double rStarS, epsilonS;							//non-bonded parameters
int line;											//non-bonded parameters
double Et;											//total energy
double Ett;
double q, qs;										//charges for isomer and SP
//////////////////////ROTATION/////////////////////////
//check if first run or not, if first use shift_arr[][] else use new xyz, txyz from input
//these first values should NOT be set, they should be obtained somehow **fix**
if(run == 1){
thx = -66.25976621 * pi / 180.000;
thy = 120.893644 * pi / 180.000;
thz = 261.891781 * pi / 180.000;
xshift = 0.18333688;
yshift = 9.258853604;
zshift = -0.041139504;
else{
	thx = thxt * pi / 180.000;
	thy = thyt * pi / 180.000;
	thz = thzt * pi / 180.000;
	xshift = xtemp;
	yshift = ytemp;
	zshift = ztemp;
xt = 0;
yt = 0;
zt = 0;
//do trig
cx = cos(thx);
sx = sin(thx);
cy = cos(thy);
sy = sin(thy);
cz = cos(thz);
sz = sin(thz);
//get matrix elements
R11 = cy * cz;
R12 = cx * sz + sx * sy * cz;
R13 = sx * sz - cx * sy * cz;
R21 = -cy * sz;
R22 = cx * cz - sx * sy * sz;
R23 = sx * cz + cx * sy * sz;
R31 = sy;
R32 = -sx * cy;
R33 = cx * cy;
//get number of atoms in Isomer1 (iMax) and stationary phase (jMax)
if(isoN == 1)
	iMax = Isomer1_arr[0][2];			//num rows [0,2] Isomer1_arr ----- iMax = Isomer1_arr_1D[0*100+2];
else
	iMax = Isomer2_arr[0][2];			//num rows [0,2] Isomer2_arr ----- iMax = Isomer2_arr_1D[0*100+2];
jMax = 17;									//num cols
//copy isomer1 or 2 to temp_arr (sheet 5)
for(int i = 0; i < iMax; i++){				//Y
	for(int j = 0; j < jMax; j++){			//X
		if(isoN == 1)
			temp_arr[i][j] = Isomer1_arr[i][j];	//[i,j]
		else
			temp_arr[i][j] = Isomer2_arr[i][j];	//[i,j]
//make transformation
for(int i = 2; i < iMax + 2; i++){
	if(isoN == 1){
		x = Isomer1_arr[i][2];						//[i,2]
		y = Isomer1_arr[i][3];						//[i,3]
		z = Isomer1_arr[i][4];						//[i,4]
	else{
		x = Isomer2_arr[i][2];						//[i,2]
		y = Isomer2_arr[i][3];						//[i,3]
		z = Isomer2_arr[i][4];						//[i,4]
	xt = x * R11 + y * R12 + z * R13;
	yt = x * R21 + y * R22 + z * R23;
	zt = x * R31 + y * R32 + z * R33;
	temp_arr[i][2] = xt + xshift;						//[i,2]
	temp_arr[i][3] = yt + yshift;						//[i,3]
	temp_arr[i][4] = zt + zshift;						//[i,4]
////////////////////END ROTATION --> ENERGY///////////////////////
//reset x,y,z values to 0.0 for reuse
x = 0.0;
y = 0.0;
z = 0.0;
//get number of atoms in Isomer 1 and SP
iMax = Isomer1_arr[0][2];								//[0,2]
jMax = SP_arr[0][2];									//[0,2]
//initialize energies
Eqt = 0.0;											//sum of the electrostatic interactions to date
Enbt = 0.0;											//sum of the non-bonded (6-12) interactions to date
Ett = 0.0;											//sum of the total energies to date
line = 2;
	x = temp_arr[i][2];								//x for isomer		//[i + 2, 2]
	y = temp_arr[i][3];								//y for isomer		//[i + 2, 3]
	z = temp_arr[i][4];								//z for isomer		//[i + 2, 4]
	rStar = temp_arr[i][5];							//rStar for isomer	//[i + 2, 5]
	epsilon = temp_arr[i][6];						//epsilon for isomer//[i + 2, 6]
	q = temp_arr[i][7];								//charge for isomer	//[i + 2, 7]
	for(int j = 2; j < jMax + 2; j++){
		xs = SP_arr[j][2];							//x for SP			//[j + 2, 2]
		ys = SP_arr[j][3];							//y for SP			//[j + 2, 3]
		zs = SP_arr[j][4];							//z for SP			//[j + 2, 4]
		rStarS = SP_arr[j][5];						//rStar for SP		//[j + 2, 5]
		epsilonS = SP_arr[j][6];					//epsilon for SP	//[j + 2, 6]
		qs = SP_arr[j][7];							//charge for SP		//[j + 2, 7]
		//calculate distance from atoms on SP
		r2 = ((x - xs) * (x - xs)) + ((y - ys) * (y - ys)) + ((z - zs) * (z - zs));
		r = sqrt(r2);								//distance between atome j on stationary phase and atom i on isomer
		//printf(i);
		//printf(j);
		//printf(r);
		if(r2 == 0.0){
			Eq = 1000000.0;
		else{
			Eq = q * qs / r * 0.529177249 * 627.509;	//A to Bohr gives hartrees which then needs conversion to kcal/mol
		Eqt = Eqt + Eq;
		//printf(Eq);
		//calculate non bonded (6-12) potentioals and ouput
		if(r == 0.0){
			Enb = 1000000.0;
		else{
			A = pow((rStar + rStarS), 12) * sqrt(epsilon * epsilonS);
			B = 2 * pow((rStar + rStarS), 6) * sqrt(epsilon * epsilonS);
			Enb =  (A / pow(r, 12)) - (B / pow(r, 6));
		Enbt = Enbt + Enb;
		//printf(Enb);
		//calculate total interaction and output
		Et = Enb + Eq;
		Ett = Et + Ett;
		//printf(Et);
		line = line + 1;
//printout total energy associated with interaction of isomer with stationary phase
//printf("total");
//printf(Eqt);
//printf(Enbt);
//printf(Ett);							//this is the total interaction energy
return Ett;
The arrays read in data in .csv files to be used. I have checked all the input and it is correct. But somewhere in here there is an error causing a NaN in the end.
I didn’t see an “isnan” in your code, it should be a valid function in device code.
It seems your question is really, “why is my code generating NAN values?”
One reason could be intermediate overflow. Intermediate values can overflow to +infinity or -infinity. Then when you use these values you can easily end up with infinity-infinity, which returns a NAN. In particular, in your code near the end I see some calls to “pow” calculating the 6th and 12th powers of some numbers then a few additions and subtractions. High powers with the pow function can easily overflow. I would start by looking there.
To slightly elaborate on the above comment: your code checks for the case r == 0, but if r is really small, then pow(r, 12) or pow(r, 6) might both still be 0 in floating point. Which would result in the subtraction of two infinities.
