Checking on data type matching in a subroutine call?
I compiled the following code using pgf90 5.2-4.
No warning message was given, while a complaint on
the mismatch of the data type was expected.
Should this kind of checking be done at compile time?
YY
! snip here
program testing
call sub1()
end program testing
subroutine sub1()
!character dummy
call sub2(dummy)
print *, dummy
end subroutine sub1
subroutine sub2(dummy)
character dummy
dummy=’?’
end subroutine sub2
Hi YY,
Actually, this is valid Fortran 77 code since F77 does not type check subroutine calls. In Fortran 90 you can add an interface which will check for this type of error. Without the interface, however, F90 will revert to the F77 convention.
     program testing
      call sub1()
      end program testing
      subroutine sub1()
!     character dummy
      interface
            character, intent(in) :: dummy
         end subroutine
      end interface
      call sub2(dummy)
      print *, dummy
      write(*,'A') dummy
      end subroutine sub1
      character dummy
      dummy='?'
      end subroutine sub2
/tmp% pgf90 x.f
PGF90-S-0188-Argument number 1 to sub2: type mismatch (x.f: 15)
  0 inform,   0 warnings,   1 severes, 0 fatal for sub1
  • Mat
This makes sense.
Thanks a lot! Mat
WRITE(*,‘A’) works with pgf90. Interesting… :)
