Jetson Linux 36.4 + Orin NX + webcam
after “sudo apt install nvidia-jetpack”
cheese doesn’t work :JPEG parameter struct mismatch: library thinks size is 584, caller expects 728
then I "export LD_PRELOAD=/usr/lib/aarch64-linux-gnu/nvidia/libnvjpeg.so " and run cheese again, still fail:
NvMMLiteOpen : Block : BlockType = 277
NvMMLiteBlockCreate : Block : BlockType = 277
(cheese:4503): cheese-WARNING **: 10:44:06.462: Internal data stream error.: …/libs/gst/base/gstbasesrc.c(3127): gst_base_src_loop (): /GstCameraBin:camerabin/GstWrapperCameraBinSrc:camera_source/GstBin:bin18/GstPipeWireSrc:pipewiresrc1:
streaming stopped, reason not-negotiated (-4)
NVMMLITE_NVVIDEODEC, NvVideoBufferProcessing:6121 Consume the extra signalling for EOS
