Chest X-ray classification model is missing a config file?
Whenever I try to load this model (clara_xray_classification_chest_amp) into AIAA, I get this error:
Model/Config Not Found OR Failed to import model into AIAA
Load with valid model+config
The non-AMP version also has this issue.
Checking the files, I suspect that it’s because of the missing config_aiaa.json file. So, does anyone have the correct config file for this model?
Hi
Thanks for your interest in Clara Train SDK. Nvidia
AIAA helps you with 3d image annotations. The chest X-ray is a 2D problem so it doesn’t have an AIAA config. Please refer to our documentation to for more information regrading AIAA which in V3 can run segmentation, Annotation and deepgrow models.
Hope that helps
