Background
I’m trying to get two MCP2515 SPI-CAN devices working on SPI1 through the J21 header. I have one device on each of the two available chip selects. The J24 jumper is set to 3.3v. My MCP2515 devices are on these breakout boards: The MicroController and Embedded System Store. I’ve used the references listed below to get to my current point.
Some shorthand:
CS = Chip select
M0 = MCP2515 connected to SPI1 CS0 (J21 header pin 24)
M1 = MCP2515 connected to SPI1 CS1 (J21 header pin 26)
Problem Description
As long as M1 is disabled, M0 behaves correctly. The MCP251x driver successfully probes M0, and the SocketCAN driver is able to create a “can0” device that is reported by ifconfig -a. The MCP251x driver’s probe of M1 fails in this case, and dmesg reports “mcp251x spi0.1: MCP251x didn’t enter in conf mode after reset”, but M0 behaves properly. I disable M1 by disconnecting its CS wire from the J21 header, and connecting it to a 3.3v rail, so its CS is never asserted.
However, if I reconnect the M1’s CS wire to J21 pin 26, both devices fail probe and no CAN network interfaces are created. A logic analyzer shows that CS1 is never deasserted. It is low as soon as SCLK begins running, and remains asserted for as long as I capture it. This causes bus contention on MOSI and MISO.
Configuration
My device tree is derived from the default tree at /boot/tegra210-jetson-tx1-p2597-2180-a01-devkit.dtb on a flashed Jetson device. These are my additions:
Under gpio@6000d000:
gpio_default: default {
* Set pins to input for RX interrupts from SPI-CAN controllers
* Controller 0: Pin 38 (PE6)
* Controller 1: Pin 219 (PBB3)
gpio-input = <38 219>;
/* Assigns default function of GPIOs to SPI conroller */
gpio-to-sfio = <16 17 18 19 20>;
I’ve opted to not add any SPI devices under spi@7000d400, because I don’t need to use spidev.
Additions to arch/arm64/mach-tegra/board-t210ref.c:
#define SPI0_INT_GPIO TEGRA_GPIO_PE6
#define SPI1_INT_GPIO TEGRA_GPIO_PBB3
static struct mcp251x_platform_data mcp251x_info = {
.oscillator_frequency = 16 * 1000 * 1000, /* Oscillator on MCP2515 board is 16MHz */
/* none of these three fields are necessary for our configuration */
.board_specific_setup = NULL,
.power_enable = NULL,
.transceiver_enable = NULL,
struct spi_board_info mcp251x_spi_board[] = {
/* SPI-CAN device 0 */
.modalias = "mcp2515", /* chip controller to use (MCP2510 also works) */
.platform_data = &mcp251x_info,
.max_speed_hz = 2 * 1000 * 1000, /* max speed of the chip in use */
.chip_select = 0, /* which CS on the SPI bus is used */
.bus_num = 0, /* Tegra SPI1 maps to our SPIO bus #0 */
.mode = SPI_MODE_0,
/* SPI-CAN device 1 */
.chip_select = 1, /* which CS on the SPI bus is used */
.mode = SPI_MODE_0,
static int __init mcp251x_init(void)
int status;
mcp251x_spi_board[0].irq = gpio_to_irq(SPI0_INT_GPIO);
mcp251x_spi_board[1].irq = gpio_to_irq(SPI1_INT_GPIO);
status = spi_register_board_info(mcp251x_spi_board, ARRAY_SIZE(mcp251x_spi_board));
printk(KERN_DEBUG "mcp251x_init: spi_register_board_info retval: %d", status);
return 0;
/* snip */
static void __init tegra_t210ref_late_init(void)
/* snip */
#ifdef CONFIG_CAN_MCP251X
mcp251x_init();
#endif
The Question
How can I fix CS1 so that it behaves properly and resolves the SPI1 bus contention?
References
https://devtalk.nvidia.com/default/topic/998947/jetson-tx1/guide-to-enabling-mcp251x-on-the-tx1-spi-/
https://devtalk.nvidia.com/default/topic/915614/jetson-tx1/did-anybody-get-spi-interface-working-on-tx1-/
https://devtalk.nvidia.com/default/topic/974743/jetson-tx1/configuring-a-can-bus-with-mcp2515-over-spi-in-tx1/1
http://elinux.org/Jetson/TX1_SPI
- spi1_cs_connected_logiccap.png: Shows failure of CS1 to ever deassert
- spi1_cs_high_logiccap.png: Shows that when CS1 is tied high, M0 is successfully probed begins communication
