I will shortly start a project concept based on a hybrid system using Jetson Orin and Raspberry Pi’s. I need to install a Kubernetes cluster on both (GPU is not initially required but is nice to have from the start).
I see threads here about K3s and MicroK8s… can I have any advice on what K8s solution to use considering the previous info? (Basically heterogeneous hardware [I’d like to use same K8s solution, not different ones in the Pi’s and in the Nano]), …
Thanks for any advice or experience on this.
k8s should work on Orin.
If you need the GPU resources, please find the topic below for a known nvidia-container issue.
Sorry that we don’t have too much experience in using Jetson and Raspberry Pi together.
You can give it a try and file a forum topic for any issues.
