I want to install an additional root file system on the SD card and use the debug port to choose from either eMMC or the SD card. How to prepare the SD card to achieve this? And what changes should I do to the u-boot to achieve this? Basically, I want to have a dual boot.
Things I tried
I split the SD card into two partitions. I copied the rootfs to the first partition (ext4) and executed
./apply_binaries.sh -r /media/SDcard/rootfs
Below is the dump of the u-boot printouts on the debug port.
U-Boot 2016.07 (Feb 28 2020 - 11:42:29 +1100)
TEGRA186
Model: NVIDIA P2771-0000-500
DRAM: 7.8 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: eth0: ethernet@2490000
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
mmc0(part 0) is current device
Scanning mmc 0:1...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
733 bytes read in 68 ms (9.8 KiB/s)
L4T boot options
1: primary kernel
Enter choice:
I am also a bit confused about the role the extlinux.conf file in the booting of the kernel. It just helps us choose between kernel images on the same partition, right?
