Hi everyone,
I’m trying to determine whether this is a driver limitation, an Optimus design limitation, or simply something I’m missing.
System
- Laptop: Dell XPS 15 9510
- CPU: Intel Tiger Lake-H (Intel UHD Graphics)
- dGPU: NVIDIA GeForce RTX 3050 Ti Laptop (GA107M)
- OS: Debian forky/sid
- Kernel: 7.1.4+deb14-amd64
- Desktop: GNOME 50.2 (Wayland only)
- Browser: Google Chrome 150.0.7871.128
- NVIDIA Driver: 610.43.02
The NVIDIA driver itself appears to work correctly:
nvidia-smiworks- CUDA works
- All kernel modules are loaded (
nvidia,nvidia_modeset,nvidia_uvm,nvidia_drm) envycontrolcan switch between hybrid and NVIDIA modes- The DRM devices are detected correctly:
- Intel:
card0,renderD128 - NVIDIA:
card1,renderD129
- Intel:
The problem
Chrome always renders on the Intel GPU.
chrome://gpu consistently reports the Intel GPU as the active rendering device. The NVIDIA GPU is detected but never becomes the active renderer.
Things I’ve already tried
DRI_PRIME=1-
fails with:
nv_gbm.c:288: GBM-DRV error: nv_common_gbm_create_device failed
--render-node-override=/dev/dri/renderD129- no effect
- Vulkan via ANGLE
- Chrome reports Vulkan is incompatible with Wayland (
--ozone-platform=wayland)
GBM_BACKEND=nvidia-drm- no change
- Switching the whole desktop to NVIDIA using
envycontrol- GNOME runs on NVIDIA, but Chrome still chooses the Intel render node.
- Various Chrome GPU flags (
--use-gl=desktop, VAAPI, ignore blocklist, etc.)- either no change or hardware acceleration becomes disabled.
My question
Is this an expected limitation of the current NVIDIA Linux driver with Wayland + Optimus?
Specifically:
- Is Chrome intentionally forced to use the render node that owns the connected displays under Wayland?
- Is PRIME Render Offload for Chromium/Chrome currently unsupported on Wayland?
- Is the
nv_common_gbm_create_device failedmessage expected on hybrid systems? - Is there currently any supported way to make Chrome/WebGL render on the NVIDIA GPU under Wayland on an Optimus laptop?
Since GNOME 50 no longer provides an X11 session, the traditional __NV_PRIME_RENDER_OFFLOAD=1 workaround is no longer an option for me.
I’m mainly trying to understand whether this is:
- an NVIDIA driver limitation,
- a Chromium/Chrome limitation,
- a Wayland protocol limitation,
- or simply unsupported on Optimus systems at the moment.
I’d especially appreciate hearing from anyone running a similar Optimus setup with recent NVIDIA drivers.
Thanks in advance!
