Circle doesnt fill Deepstream 6.0.1
When I try to add circles to the output, the function fill doesn’t work, any idea how to fix that ?
NvDsDisplayMeta *display_meta =
      nvds_acquire_display_meta_from_pool (batch_meta);
  NvOSD_CircleParams *circle_params = display_meta->circle_params;
  for ( int j=0; j < 1; j++ )
    circle_params[j].xc = 200;
    circle_params[j].yc = 200;
    circle_params[j].radius = 30;
    circle_params[j].has_bg_color = True;
    circle_params[j].bg_color = (NvOSD_ColorParams){0.0, 1.0, 0.0, 1.0};
    circle_params[j].circle_color = (NvOSD_ColorParams){0.0, 1.0, 0.0, 1.0};
    display_meta->num_circles ++;
  nvds_add_display_meta_to_frame (nvds_get_nth_frame_meta (batch_meta->
          frame_meta_list, 0), display_meta);
Which demo did you run? Our demo or your own demo?
Could your please provide complete information as applicable to your setup?
• DeepStream Version
• TensorRT Version
I’m running the deepstream-test-5-app on the Jetson nano,(DS 6.0) where i have added these lines of code in order to draw circles in the graphics_overlay_function, I have edited the deepstream-test-5-main.c and built it using sudo make
    circle_params[j].has_bg_color = True; // DOESENT WORK
    circle_params[j].bg_color = (NvOSD_ColorParams){0.0, 1.0, 0.0, 1.0}; // DOESENT WORK
The circles do appear but without the infill, i’m not sure if i have made a wrong definiton to the parameters or is it a source code problem.
Could you try to set the paras to 1 like: circle_params[j].has_bg_color = 1; and use the deepstream_test_1.c to test it? Test1 is more simple to verify this problem.
Still doesn’t make any difference
Yes, we can reproduce this issue with DeepStream 6.0 on Jetson Nano, and not reproduce this issue on the latest DeepStream 6.2.
Is it possible for you to switch to DeepStream 6.2(x86 or Xavier/XavierNX/Orin/OrinNX can support DS6.2)?
