Is it possible to create a circular plane that works like the object from the class Plane (from geometry.primitives_3d)?
Hi @tom_02
I suppose there are a couple options you could try:
- Use a boolean operations to union a plane and 3D cylinder
- Have a cylinder with a very small height (shouldn’t make too much of a difference to the NN)
- Create a cylinder and sample one of the top/bottom boundaries
- Create your own 3D circle primitive based on the Plane and 2D ellipse class
