Circular buffer class on device (new[] operator)
I am writing a circular buffer class (actually a struct) for running on the device (i.e. kernel). How can I allocate memory in the constructor? It seems like I wasn’t allowed to allocate memory once I’m running inside a kernel, so any suggestion on how to implement this?
cuda 3.2 makes this possible with fermi class hardware. Check the malloc function call support that is new in 3.2
I’m using GTX 450 (Fermi) with CUDA Toolkit 3.2, and the host is MATLAB (so I’m compiling the PTX file first). For the two lines in my kernel,
char* ptr = (char*)malloc(123);
free(ptr);
I got:
D:/Work/Research/MAF/simulation/gpu/sysID_branch.cu(146): error: calling a host function from a device/global function is not allowed
D:/Work/Research/MAF/simulation/gpu/sysID_branch.cu(147): error: calling a host function from a device/global function is not allowed
Did I miss something? The same thing happens when I tried printf().
free(ptr);
I got:
the -arch sm_20 command line option to nvcc is probably needed. You can check how printf should work since there is a printf example in the SDK.
After I changed from -arch=sm_13 to -arch=sm_20 and I got the following error when MATLAB is trying to generate the kernel from the PTX file:
"??? Error using ==> parallel.gpu.CUDAKernel
An error occurred during PTX compilation of .
The information log was:
: Considering profile ‘compute_20’ for gpu=‘sm_21’ in ‘cuModuleLoadDataEx_136’
: Retrieving binary for ‘cuModuleLoadDataEx_136’, for gpu=‘sm_21’, usage mode=’ ’
: Control flags for ‘cuModuleLoadDataEx_136’ disable search path
: Ptx binary found for ‘cuModuleLoadDataEx_136’, architecture=‘compute_20’
: Ptx compilation for ‘cuModuleLoadDataEx_136’, for gpu=‘sm_21’, ocg options=’
The error log was:
The CUDA error code was: CUDA_ERROR_INVALID_IMAGE."
Any ideas?
The error log was:
Any ideas?
I see messages of sm_21. Do you have a sm_21 device?
I have no idea. It’s a GTS 450. I changed to arch=sm_21 and got this:
: Considering profile ‘compute_20’ for gpu=‘sm_21’ in ‘cuModuleLoadDataEx_139’
: Retrieving binary for ‘cuModuleLoadDataEx_139’, for gpu=‘sm_21’, usage mode=’ ’
: Control flags for ‘cuModuleLoadDataEx_139’ disable search path
: Ptx binary found for ‘cuModuleLoadDataEx_139’, architecture=‘compute_20’
: Ptx compilation for ‘cuModuleLoadDataEx_139’, for gpu=‘sm_21’, ocg options=’
The error log was:
The error log was:
the devicequery example from the sdk can tell you the compute capability of your card. My guess is that your GPU is not 2.x capable so it cannot do in-kernel malloc on the device.
Here’s my GPU’s device query:
gpuDevice
ans =
parallel.gpu.CUDADevice handle
Package: parallel.gpu
Properties:
                  Name: 'GeForce GTS 450'
                 Index: 1
     ComputeCapability: '2.1'
        SupportsDouble: 1
         DriverVersion: 3.2000
    MaxThreadsPerBlock: 1024
      MaxShmemPerBlock: 49152
    MaxThreadBlockSize: [1024 1024 64]
           MaxGridSize: [65535 65535]
             SIMDWidth: 32
           TotalMemory: 1.0417e+009
            FreeMemory: 996872192
   MultiprocessorCount: 4
  GPUOverlapsTransfers: 1
KernelExecutionTimeout: 0
       DeviceSupported: 1
        DeviceSelected: 1
Seems like I have compute capability 2.1.
gpuDevice
ans =
Properties:
                 Index: 1
        SupportsDouble: 1
             SIMDWidth: 32
       DeviceSupported: 1
        DeviceSelected: 1
Then I would file a bug-report with the Mathworks. ( support@mathworks.com : their support is great)
