MCP server — Compressed Knowledge Graph (CKG) for the full NVIDIA AI developer stack.
4× F1 · 11× fewer tokens · 998 nodes · deterministic traversal.
Read-only. This MCP server never writes, mutates, or executes. Every response is a declared graph traversal — not inference, not retrieval, not generation.
The problem every AI team hits
More agents. More retrieval. More context. And accuracy drops.
Every time your agent asks what TensorRT-LLM requires to run on Hopper, it spends ~2,982 tokens re-inferring a relationship that could be declared once and traversed in 269. That difference compounds across every query, every agent, every boundary crossing.
The fix is not a better model. It is structured context.
What this package does
A CKG is a layer — a fast, inexpensive way to convert domain documentation into structured, agent-traversable knowledge. Instead of retrieval, the agent traverses. Instead of inference, it reads declared relationships.
query_ckg("TensorRT-LLM", "nvidia-tensorrt-triton", depth=3)
→ TensorRT-LLM requires:
CUDA Toolkit → CUDA Driver API, cuBLAS
FP8 / FP4 Quantization → Hopper SM90 Architecture
TensorRT-LLM enables:
Triton Inference Server → NIM Microservice Runtime
That traversal cost 269 tokens. A RAG call over the same question costs ~2,982. The graph doesn’t guess — it traverses.
Explore the graph
Paste this into Claude, Cursor, or any MCP client:
You have access to the nvidia-ai CKG. I want to understand what it actually takes to deploy
a real-time speech AI pipeline on NVIDIA Jetson at the edge — not the marketing version,
the real dependency chain.
Start here:
get_prerequisites("Riva ASR", "nvidia-riva")
Then follow the chain into the inference layer:
Then map the edge hardware:
get_prerequisites("Jetson Orin NX", "nvidia-jetson")
Present the result as a layered architecture map — foundation at the bottom, application at the
top, typed edges (REQUIRES / ENABLES) labeled between layers. Show where the three domains share
prerequisites. Flag anything that would block a cold-start deployment.
Quickstart
pip install ckg-nvidia-ai
uvx ckg-nvidia-ai
Claude Desktop
"mcpServers": {
"nvidia-ai": {
"command": "uvx",
"args": ["ckg-nvidia-ai"]
Claude Code
claude mcp add nvidia-ai -- uvx ckg-nvidia-ai
Cursor / Cline / Windsurf
{ "mcpServers": { "nvidia-ai": { "command": "uvx", "args": ["ckg-nvidia-ai"] } } }
System prompt snippet
You have access to the nvidia-ai MCP server — a typed dependency graph of 20 NVIDIA AI domains
(NIM, NeMo, TensorRT, CUDA, Isaac, Cosmos, Riva, and 13 more). When answering questions about
NVIDIA infrastructure, prerequisites, or deployment, call query_ckg() or get_prerequisites()
before responding. Do not guess dependency chains — traverse the graph instead.
Accuracy model
Every edge was declared by a human reviewer. Corrections arrive from the community weekly.
Three-state confidence:
| State |
Meaning |
How to use |
confidence: high |
Reviewed, cross-referenced with NVIDIA docs |
Trust for planning |
confidence: null |
Plausible, not yet audited |
Scaffold — verify before production |
confidence: low |
Flagged as uncertain |
Treat as a hint, not a fact |
Typed edges:
| Type |
Meaning |
Agent use |
REQUIRES |
Hard prerequisite |
Plan sequencing, gap detection |
ENABLES |
Unlocks a capability |
Optimization paths |
RELATES_TO |
Conceptual proximity |
Disambiguation, context |
IMPLEMENTS |
Concrete instantiation |
Architecture mapping |
If an edge isn’t declared, the traversal returns nothing rather than hallucinating a path. That silence is signal.
Tools
| Tool |
What it does |
list_domains() |
All 20 NVIDIA AI domains — start here |
search_concepts(query, domain) |
Find concepts by keyword |
query_ckg(concept, domain, depth=3) |
Traverse prerequisites and dependents |
get_prerequisites(concept, domain) |
Full ordered upstream chain |
ask_nvidia(question, domain) |
Natural language, grounded on graph via Ollama — no API key |
Benchmark
Evaluated on KRB Benchmark v0.6.2 — open dataset, reproducible methodology.
| System |
Macro F1 |
Tokens/query |
Cost/1K queries |
| CKG (this package) |
0.471 |
269 |
$7.81 |
| RAG (text-embedding-3-small) |
0.123 |
2,982 |
$76.23 |
| GraphRAG (MS global mode) |
0.120 |
4× F1 · 11× fewer tokens · 5-hop F1 0.772 vs 0.170
Corrections welcome
Spotted a wrong edge? A RELATES_TO that should be REQUIRES? A missing concept in Riva or AgentIQ?
Edge corrections are the highest-value contribution. Open an issue or PR: GitHub - Yarmoluk/ckg-nvidia-ai: MCP server — Compressed Knowledge Graph for the NVIDIA AI developer stack. 20 domains · 998 nodes · 4× F1 vs RAG · 11× fewer tokens · deterministic traversal. · GitHub
