I try to implement an optimisation algoritme for the travelling tournament problem in OpenCL. I know my algorithm works fine. After a few hours puzzeling I implemented my code on a nVidea GPU. If I test my code with a small counter maximum, it works fine. However if I increase that number my code exits with a clwaitforevents error. It is impossible to get the optimal solution without those huge number of iterations. How can I avoid this error?
Okay, I tried to catch the error by checking with event.getInfo<CL_EVENT_COMMAND_EXECUTION_STATUS>()
The error has dissapeard but the program keeps running instead. Although I’m sure it must have been finished already!
I noticed the screen blinking after 15seconds. When execution time is above this number my program will never ever get executed. Is it possible that it is a driver problem?
I installed a recent driver. Now my program gives me
Run-Time Check Failure #0 - The value of ESP was not properly saved across a function call. This is usually a result of calling a function declared with one calling convention with a function pointer declared with a different calling convention.
in the cl.hpp file. If I replace the cl.h file with a recent one (from sdk 3.0) I get the errors from
