clamp quesiton
hey there
I’m using this way to read data through texture:
[codebox]texture<float,1> tex_x_float_A; // as global variable
cudaChannelFormatDesc channelDesc =
    cudaCreateChannelDesc(32, 0, 0, 0, cudaChannelFormatKindFloat);
cudaError_t err = cudaBindTexture(0,tex_x_float_A,A,channelDesc);
tex1Dfetch(tex_x_float_A, i);[/codebox]
In this way, does clamp work if variable i is too large and falls out of boundary?
Clamping should be the default behaviour in that case, yes.
Just out of curiosity, how does CUDA know the size of the array A so that it knows where the boundary is?
If you’re using tex1Dfetch you don’t get clamping or filtering (see programming guide B.8.1). tex1Dfetch isn’t like a real texture lookup, it’s just a convenient way to read memory taking advantage of the texture cache and without coalescing restrictions.
BTW, you do have to specify the memory size when calling cudaBindTexture.
