Clara Deploy SDK does not work on EC2 p3 8x Instance
Hey Nvidia Engineers,
I’m encountering with a couple of errors with Clara Deploy SDK on EC2 P3 8x Instance. And it seems that Clara Deploy SDK does not work on EC2 p3 8x Instance. I don’t why such errors appear over and over again even after reinstalling the Clara Deploy SDK prerequisites i.e bootstrap.sh as per https://docs.nvidia.com/clara/deploy/ClaraInstallation.html#steps-to-install
While first starting Clara Platform with cmd “clara platform start” on EC2 p3 8x Instances on AWS, it hung and didn’t respond, and then later after 30 minutes I closed console and reopened to start with the same as follows incl. as in the image attachment, but again failed to start with various errors.
ubuntu@ip-XXX-XX-XX-XXX:~$ clara platform start
rpc error: code = Unknown desc = a release named clara already exists.
Run: helm ls --all clara; to check the status of the release
Or run: helm del --purge clara; to delete it
ubuntu@ip-XXX-XX-XX-XXX:~$ helm ls --all clara
NAME REVISIONUPDATED STATUS CHART
APP VERSIONNAMESPACE
clara1 Fri May 22 18:46:30 2020PENDING_INSTALLclara-0.5.0-2
004.71.0 default
rpc error: code = Unknown desc = unable to get CRD: customresourcedefinitions.apiexte
nsions.k8s.ioinferenceservers.clara.nvidia.com” not found
One more error as follows:
ubuntu@ip-XXX-XX-XX-XXX:~/.clara/pipelines/clara_ai_covid19_pipeline$ clara create pi
pelines -p COVID-19-pipeline.yaml
E0522 13:28:36.758190 129421 portforward.go:400] an error occurred forwarding 34351
-> 50051: error forwarding port 50051 to pod bac8784f3ecb1352914c8c7c9f12c3e1aefb30ed
f1f7ce2f1608e5a802e6c64c, uid : exit status 1: 2020/05/22 13:28:36 socat[129442] E co
nnect(5, AF=2 127.0.0.1:50051, 16): Connection refused
Unable to create pipeline. Error:rpc error: code = Unavailable desc = connection clos
ed
I kindly request you to look into it and provide me with the resolution to get started with to make Clara up and running and to dive deeper into it as soon as possible.
KINDLY PLEASE HELP US AS SOON AS POSSIBLE!
I’M LOOKING FORWARD TO YOUR RESPONSE!
I think that the error I have shared in this case was returned by the Kubernetes.
So I kindly request you to look into it and provide me with the resolution to get started with to make Clara up and running and to dive deeper into it as soon as possible.
