Clara-render-server-clara-renderer POD does not running normally
I started render with below command:
clara pull render
clara render start
After that, I confirmed the POD status and get below:
clara-render-server-clara-renderer-6b9d4799f6-2jx7k 2/3 CrashLoopBackOff 8 19m
Since I restarted render, above problem couldn’t be solved…
Please teach me how I do.
Thank you.
Additional information.
My kubernetes env is below:
GPU: Quadro RTX6000
kubectl, kubeadm, kubelet : v1.19.15
docker.io : 20.10.9
Hey yasu18, thanks for your interest in the Clara Deploy platform.
Can you provide the output of the following? We need to see why the renderer hasn’t started.
kubectl describe node
kubectl describe pod <clara-render-server-clara-renderer-HASH>
It would also be helpful to get logs from the containers in the render server pod. Using the pod name above, do something along the lines of:
RENDERPOD=<clara-render-server-clara-renderer-HASH>
for i in $(kubectl get pods $RENDERPOD -o jsonpath='{.spec.containers[*].name}');
    do echo $i:;
    kubectl logs --tail 20 $RENDERPOD $i;
    echo -e "\n";
done
You may have to adjust the length of the tail argument to get relevant info.
Let me know if you run into any trouble capturing logs. Good luck!
-Kris
