• Hardware Platform (Jetson / GPU): GeForce RTX 2080 Ti
• DeepStream Version: 5.0
• TensorRT Version: 10.2
• NVIDIA GPU Driver Version (valid for GPU only): 450
• Issue Type( questions, new requirements, bugs): question
* Holds unclipped bounding box coordinates of the object.
typedef struct _NvBbox_Coords {
float left; /**< Holds the box's left coordinate
in pixels. */
float top; /**< Holds the box's top coordinate
in pixels. */
float width; /**< Holds the box's width in pixels. */
float height; /**< Holds the box's height in pixels. */
} NvBbox_Coords;
Are these values relative to the detector input dimensions, muxer output dimensions or the source frame dimensions, assuming that these 3 dimensions are different?
