Hello NVIDIA Omniverse team,
I would like to clarify my understanding of LOD in NVIDIA Omniverse, USD Composer, and Isaac Sim.
In traditional game engines such as Unity or Unreal Engine, LOD usually means:
Preparing LOD0 / LOD1 / LOD2 meshes
Switching to lower-poly meshes based on camera distance or screen size
Using LOD mainly as a real-time rendering performance optimization technique
However, based on my current understanding, LOD in Omniverse / USD / Isaac Sim should not be interpreted in exactly the same way.
My understanding is as follows:
In Omniverse, LOD is not primarily a simple “distance-based low-poly mesh switching” feature like in game engines. Instead, it seems to be part of a broader USD-based optimization strategy for handling large USD, CAD, and SimReady scenes.
This broader optimization strategy may include:
Scene Optimizer
USD Variant Sets
USD Payloads / References
RTX Geometry Streaming / Auto LOD
SimReady asset structure
Separation of visual mesh, collision mesh, and proxy mesh
Scene assembly or loading control through Python, Kit, or Isaac Sim APIs
So internally, we are considering summarizing the concept like this:
“LOD in Omniverse should be understood less as a traditional low-poly distance-switching system, and more as part of a USD-based optimization strategy that combines scene structure, renderer memory management, simulation representation, and loading strategy.”
For example, in a game engine workflow:
Artist / TA creates LOD0, LOD1, LOD2
→ Engine automatically switches LODs based on distance or screen size
But in an Omniverse / USD / Isaac Sim workflow, it seems more like:
Artist / TA prepares optimized USD assets, proxy meshes, collision meshes, variants, and payload-ready structures
→ Developer / TD assembles and controls the scene through USD composition, Python, Kit, or Isaac Sim APIs
→ RTX Geometry Streaming or Auto LOD may help internally with renderer-side memory and geometry management
Is this interpretation correct?
More specifically, I would like to ask:
Is it correct to say that Omniverse does not primarily use traditional game-engine-style distance-based LOD switching as its main LOD workflow?
Is RTX Geometry Streaming / Auto LOD mainly an internal renderer-side memory and performance optimization feature, rather than a replacement for manually authored LOD meshes?
If we want high / low / proxy / collision-only representations in USD, is using Variant Sets, Payloads, References, and separate visual/collision/proxy assets the recommended approach?
In Isaac Sim, should optimization be considered more as a pipeline task involving artists, TAs, TDs, and developers, rather than something that can be fully handled by modelers alone?
For large CAD-based or SimReady scenes, is it reasonable to treat Scene Optimizer, Payloads, Variants, Geometry Streaming, and visual/collision/proxy separation as parts of one overall optimization workflow?
We are trying to define an internal guideline for how our team should understand and assign responsibilities for Omniverse optimization work.
Any clarification or correction would be very helpful.
Thank you.
