Clarification on resistor values in TX1 Data sheets for HDMI
While we were designing an HDMI connector for the Jetson TX1 module, we saw the following resistor values printed like 60 0 and 49 9 ohms. Wanted to check if these values are indeed 499 and 600 ohms or is there a missing decimal?
Here is a link to the part of circuit we were looking at from the data sheet HDMI example
[url]Dropbox - File Deleted
The beads are 600ohm@100MHz.
The resistors are 499ohm.
You can get the details in board’s BOM [url]http://developer.nvidia.com/embedded/dlc/jetson-tx1-tx2-developer-kit-carrier-board-bom[/url]
Thanks very much!
