when working through the examples it seems that the primary GIE is always a object detecter.
In my current setup i have a camera as input and a rtsp stream as output using a modified config from the YOLOv3 object detector in the samples. I would like to change this YOLOv3 model to a single classifier.
I have the following questions:
-how to specify input blob size of the classifer in primary-GIE
-The input image from camera is 1920*1080 and the same for the output stream, how to resize image for classifier?
it would be helpful if you can recommend or give a sample config to modify
thanks in advance
1. Network size is defined in the cfg file.
Ex. yolov2.cfg
[net]
# Testing
batch=1
subdivisions=1
# Training
# batch=64
# subdivisions=8
width=608
height=608
channels=3
2. The resize is applied automatically between network and stream.
The network seems to function correctly! however i can’t figure out how to display the confidence of my sigmoid output. The parse-bbox-func-name property seems to handle the displaying of this information.
Do i have to write a custom function for the parse-bbox-func-name property or is there a easier way to pass the information to the on screen display?
i ended up modifying the nvdsinfer_customclassifierparser.cpp in sources/libs/nvdsinfer_customparser to write the confidence in the label field. A bit of a hacky solution but it works.
#include <cstring>
#include <iostream>
#include "nvdsinfer_custom_impl.h"
/* C-linkage to prevent name-mangling */
extern "C"
bool NvDsInferClassiferParseCustomSigmoid (std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
NvDsInferNetworkInfo const &networkInfo,
float classifierThreshold,
std::vector<NvDsInferAttribute> &attrList,
std::string &descString);
static std::vector < std::vector< std:: string > > labels { {
"good"} };
extern "C"
bool NvDsInferClassiferParseCustomSigmoid(std::vector<NvDsInferLayerInfo> const &outputLayersInfo,
//read sigmoid probability
float *outputCoverageBuffer = (float *)outputLayersInfo[0].buffer;
float probability = outputCoverageBuffer[0];
std::cout << probability << std::endl;
//convert probability to c-style string
std::string str = std::to_string(probability);
char * prob_c = new char [str.length()+1];
std::strcpy (prob_c, str.c_str());
//write probability to attribute label
NvDsInferAttribute attr;
attr.attributeLabel = prob_c;
attr.attributeConfidence = probability;
attrList.push_back(attr);
if (attr.attributeLabel){
descString.append(attr.attributeLabel).append(" ");
return true;
/* Check that the custom function has been defined correctly */
CHECK_CUSTOM_CLASSIFIER_PARSE_FUNC_PROTOTYPE(NvDsInferClassiferParseCustomSigmoid);
