• Hardware (RTX)
• Network Type (Classification)
• TLT Version (5.5.0)
• Training spec file(If have, please share here)
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I’m having some difficulties exporting a SGIE/TF2 classifier to my Deepstream application. With previous versions I had no problems with the process, it was exporting and using the TAO converter to convert an .etlt to a .trt engine.
With the TAO Image classification (TF2) everything in the ipynb notebook is clear untill step 10
Note: I’m training a model with QAT.
When exporting the QAT model with:
Convert QAT model to TensorRT engine
!mkdir -p $LOCAL_EXPERIMENT_DIR/export_qat
!sed -i “s|EXPORTDIR|$USER_EXPERIMENT_DIR/export_qat|g” $LOCAL_SPECS_DIR/spec_retrain_qat.yaml
!tao model classification_tf2 export -e $SPECS_DIR/spec_retrain_qat.yaml
It outputs only a efficientnet-b0.qat.onnx
If I want to convert the trained model for a Jetson (deepstream app), do I use the onnx model as input for the TAO-converter?
The TAO-converter only specifies how to use a etlt as input.
Or do I need to use TRTexec?
Im kinda lost Thnanks in advance for the help!
