Classification model using TLT 3.0
Hi all,
I have trained a classification sample model using the steps provided in the TLT Jupyter Notebook → TLT Quick Start Guide — Transfer Learning Toolkit 3.0 documentation
The model training is complete and I have generated and exported the model which creates the following model files,
I want to know how to run this model as a secondary classifier for testing it out. My machine successfully runs the deepstream app for classification of vehicle types and make. I used the same config and changed the model paths and tried running it and it results in an error.
Here is my config files and app file,
# Copyright (c) 2020, NVIDIA CORPORATION. All rights reserved.
# Permission is hereby granted, free of charge, to any person obtaining a
# copy of this software and associated documentation files (the "Software"),
# to deal in the Software without restriction, including without limitation
# the rights to use, copy, modify, merge, publish, distribute, sublicense,
# and/or sell copies of the Software, and to permit persons to whom the
# Software is furnished to do so, subject to the following conditions:
# The above copyright notice and this permission notice shall be included in
# all copies or substantial portions of the Software.
# THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
# IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
# FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
# THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
# LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
# FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
# DEALINGS IN THE SOFTWARE.
[property]
gpu-id=0
net-scale-factor=1
offsets=124;117;104
tlt-model-key=nvidia_tlt
tlt-encoded-model=/home/glueck/Downloads/Classification/final_model.etlt
labelfile-path=/home/glueck/Downloads/Classification/labels.txt
model-engine-file=/home/glueck/Downloads/Classification/classification.engine
input-dims=3;224;224;0
uff-input-blob-name=input_1
batch-size=4
process-mode=2
model-color-format=0
operate-on-gie-id=1
network-mode=2
network-type=1
num-detected-classes=37
interval=0
gie-unique-id=6
output-blob-names=predictions/Softmax
classifier-threshold=0.2
[application]
enable-perf-measurement=1
perf-measurement-interval-sec=1
[tiled-display]
enable=1
rows=1
columns=1
width=1280
height=720
gpu-id=0
[source0]
enable=1
#Type - 1=CameraV4L2 2=URI 3=MultiURI
type=3
num-sources=1
#uri=file://../../streams/sample_1080p_h265.mp4
uri=file://../../streams/test/Glueck/2021-05-20-150357 (convert-video-online.com).mp4
#uri=rtsp://root:Glueck321@10.0.1.36/axis-media/media.amp?streamprofile=H264
#drop-frame-interval=2
gpu-id=0
[streammux]
gpu-id=0
batch-size=1
batched-push-timeout=40000
## Set muxer output width and height
width=1920
height=1080
[sink0]
enable=1
#Type - 1=FakeSink 2=EglSink 3=File
type=2
sync=0
source-id=0
gpu-id=0
[osd]
enable=1
gpu-id=0
border-width=3
text-size=15
text-color=1;1;1;1;
text-bg-color=0.3;0.3;0.3;1
font=Arial
[primary-gie]
enable=1
gpu-id=0
# Modify as necessary
model-engine-file=../../models/Primary_FaceDetector/resnet18_detector.etlt_b1_gpu0_fp16.engine
batch-size=1
bbox-border-color0=1;0;0;1
bbox-border-color1=0;1;1;1
bbox-border-color2=0;0;1;1
bbox-border-color3=0;1;0;1
gie-unique-id=1
config-file=config_infer_primary_facedetectir.txt
[sink1]
enable=0
type=3
#1=mp4 2=mkv
container=1
#1=h264 2=h265 3=mpeg4
codec=1
#encoder type 0=Hardware 1=Software
enc-type=0
sync=0
bitrate=2000000
#H264 Profile - 0=Baseline 2=Main 4=High
#H265 Profile - 0=Main 1=Main10
profile=0
output-file=out.mp4
source-id=0
[sink2]
enable=0
#Type - 1=FakeSink 2=EglSink 3=File 4=RTSPStreaming 5=Overlay
type=4
#1=h264 2=h265
codec=1
enc-type=0
sync=0
bitrate=4000000
profile=0
# set below properties in case of RTSPStreaming
rtsp-port=8554
udp-port=5400
[tracker]
enable=0
tracker-width=640
tracker-height=384
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_iou.so
ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_nvdcf.so
#ll-lib-file=/opt/nvidia/deepstream/deepstream-5.1/lib/libnvds_mot_klt.so
#ll-config-file required for DCF/IOU only
ll-config-file=../deepstream-app/tracker_config.yml
#ll-config-file=iou_config.txt
gpu-id=0
#enable-batch-process applicable to DCF only
enable-batch-process=1
[secondary-gie0]
enable=0
#model-engine-file=../../models/Secondary_Gender/gender11.caffemodel_b16_gpu0_fp16.engine
gpu-id=0
batch-size=16
gie-unique-id=2
operate-on-gie-id=1
operate-on-class-ids=0;
config-file=config_infer_gender_classifier.txt
[secondary-gie1]
enable=0
#model-engine-file=../../models/Secondary_Age/age.model_b16_gpu0_fp16.engine
gpu-id=0
batch-size=16
gie-unique-id=3
operate-on-gie-id=1
config-file=config_infer_age_classifier.txt
[secondary-gie2]
enable=0
model-engine-file=../../models/Secondary_Emotion/emotion_2convs_iter_3000.caffemodel_b16_gpu0_fp16.engine
gpu-id=0
batch-size=16
gie-unique-id=4
operate-on-gie-id=1
config-file=config_infer_emotion_classifier.txt
[secondary-gie3]
enable=0
model-engine-file=../../models/Secondary_Ethnicity/ethnicity_generic.caffemodel_b16_gpu0_fp16.engine
gpu-id=0
batch-size=16
gie-unique-id=5
operate-on-gie-id=1
config-file=config_infer_ethnicity_classifier.txt
[secondary-gie4]
enable=0
model-engine-file=../../models/Secondary_FaceMask/caffe_model_1_iter_100000.caffemodel_b16_gpu0_fp16.engine
gpu-id=0
batch-size=16
gie-unique-id=6
operate-on-gie-id=1
config-file=config_infer_mask_classifier.txt
[secondary-gie5]
enable=1
gpu-id=0
batch-size=16
gie-unique-id=6
operate-on-gie-id=1
config-file=config_classificationtest.txt
[tests]
file-loop=1
I have added the current trained classification model as [secondary-gie5] to the working app config file which was created and tested. The test video I added as input consists of the classes required for the model like car,boat,people etc.
Please help and let me know where I am going wrong.
What is the error? Please share full command line along with the full log.
Hi @Morganh,
There was some path issue which caused the issue now I set the paths correctly the app works.
  • The primary detector here is Face
  • The secondary detector is the sample model from classification jupyter notebook. I am planning to train this classification model for gender and age, before that tried to run the sample model training and now want to test that.
I have added the trained model to the exisiting primary face detector to check if it working. There is no label change in the case (attached video) and is there any other code to check this classification model after training if we are training for custom classes.
Labels file is as follows:
boat;motorbike;sofa;chair;bicycle;train;pottedplant;horse;cat;bottle;dog;cow;diningtable;tvmonitor;sheep;car;person;aeroplane;bus;bird
The label is in alphabetic order.
Refer to Image Classification — Transfer Learning Toolkit 3.0 documentation
