Hello, can I run classification without tracker in deepstream?
In gst-nvinfer documentation there is following part: “When the plugin is operating as a secondary classifier along with the tracker…” but I don’t see information what happans when plugin is operating as a secondary classifier without the tracker.
When I disable tracker in /opt/nvidia/deepstream/deepstream-6.2/samples/configs/deepstream-app/source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt there is no classification results.
• Hardware Platform (Jetson / GPU) • DeepStream Version • JetPack Version (valid for Jetson only) • TensorRT Version • NVIDIA GPU Driver Version (valid for GPU only) • Issue Type( questions, new requirements, bugs) • How to reproduce the issue ? (This is for bugs. Including which sample app is using, the configuration files content, the command line used and other details for reproducing) • Requirement details( This is for new requirement. Including the module name-for which plugin or for which sample application, the function description)
