clCreateContext fails with error code -6
Hi all,
I have a fairly basic function that initializes OpenCL resources. I do not why but it fails in creating clCreateContext with error code -6 which corresponds to CL_HOST_OUT_OF_MEMORY. I open the task manager and it shows 2GB of memory in use and I still have 6GB left so why am i getting this error?
Here is the code:
#include "cl_resources.h"
#ifdef _CHAR16T
#define CHAR16_T
#endif
#include "mex.h"
cl_context          context;
cl_device_id        *devices;
cl_command_queue    commandQueue;
cl_program program;
cl_kernel  kernel;
 * Converts the contents of a file into a string
int convertToString(const char *filename, std::string& s)
    size_t size;
    char*  str;
std::fstream f(filename, (std::fstream::in | std::fstream::binary));
if(f.is_open())
        size_t fileSize;
        f.seekg(0, std::fstream::end);
        size = fileSize = (size_t)f.tellg();
        f.seekg(0, std::fstream::beg);
str = new char;
        if(!str)
            f.close();
            return NULL;
f.read(str, fileSize);
        f.close();
        str = '\0';
s = str;
        delete[] str;
        return 0;
    mexPrintf("Error: Failed to open file %s\n", filename);
    return 1;
 * \brief OpenCL related initialization
 *        Create Context, Device list, Command Queue
 *        Create OpenCL memory buffer objects
 *        Load CL file, compile, link CL source
 *		  Build program and kernel objects
int initializeCL(void)
    cl_int status = 0;
size_t deviceListSize;
     * Have a look at the available platforms and pick either
     * the AMD one if available or a reasonable default.
cl_uint numPlatforms;
    cl_platform_id platform = NULL;
    status = clGetPlatformIDs(0, NULL, &numPlatforms);
    if(status != CL_SUCCESS)
        mexPrintf("Error: Getting Platforms. (clGetPlatformsIDs)\n");
        return 1;
if(numPlatforms > 0)
        cl_platform_id* platforms = (cl_platform_id *)malloc(numPlatforms*sizeof(cl_platform_id));
        status = clGetPlatformIDs(numPlatforms, platforms, NULL);
            mexPrintf("Error: Getting Platform Ids. (clGetPlatformsIDs)\n");
            return 1;
        for(unsigned int i=0; i < numPlatforms; ++i)
            char pbuff[100];
            status = clGetPlatformInfo(
                        platforms[i],
                        CL_PLATFORM_VENDOR,
                        sizeof(pbuff),
                        pbuff,
                        NULL);
                mexPrintf("Error: Getting Platform Info. (clGetPlatformInfo)\n");
                return 1;
            platform = platforms[i];
            if(!strcmp(pbuff, "Advanced Micro Devices, Inc."))
                break;
        delete platforms;
if(NULL == platform)
        std::cout << "NULL platform found so Exiting Application." << std::endl;
        return 1;
     * If we could find our platform, use it. Otherwise use just available platform.
cl_context_properties cps[3] = { CL_CONTEXT_PLATFORM, (cl_context_properties)platform, 0 };
    // Create an OpenCL context
	cl_uint uiNumDevices;
	status = clGetDeviceIDs(platform, CL_DEVICE_TYPE_GPU, 0, NULL, &uiNumDevices);
        mexPrintf("Error: Creating Context. (clCreateContextFromType) error in NumDevices status is %d\n", status);
        return 1;
	devices = (cl_device_id *)malloc(uiNumDevices * sizeof(cl_device_id) );
    status = clGetDeviceIDs(platform, CL_DEVICE_TYPE_GPU, uiNumDevices, devices, NULL);
        mexPrintf("Error: Creating Context. (clCreateContextFromType) clGetDeviceIds status is %d\n", status);
        return 1;
	context = clCreateContext(0, uiNumDevices, devices, NULL, NULL, &status);
  //context = clCreateContextFromType(cps, CL_DEVICE_TYPE_GPU, NULL, NULL, &status);
        mexPrintf("Error: Creating Context. (clCreateContext) status is %d\n", status);
		mexPrintf("uiNumDevices %d\n", uiNumDevices);
        return 1;
/* First, get the size of device list data */
    status = clGetContextInfo(context,
                              CL_CONTEXT_DEVICES,
                              0,
                              NULL,
                              &deviceListSize);
        mexPrintf(
            "Error: Getting Context Info \
            (device list size, clGetContextInfo)\n");
        return 1;
    // Detect OpenCL devices
   // devices = (cl_device_id *)malloc(deviceListSize);
    if(devices == 0)
        mexPrintf("Error: No devices found.\n");
        return 1;
/* Now, get the device list data */
                 context,
                 CL_CONTEXT_DEVICES,
                 deviceListSize,
                 devices,
                 NULL);
        mexPrintf("Error: Getting Context Info \
            (device list, clGetContextInfo)\n");
        return 1;
    // Create an OpenCL command queue
    commandQueue = clCreateCommandQueue(
                       context,
                       devices[0],
                       0,
                       &status);
        mexPrintf("Creating Command Queue. (clCreateCommandQueue)\n");
        return 1;
    // Load CL file, build CL program object, create CL kernel object
    const char * filename  = "sts_kernel.cl";
    std::string  sourceStr;
    status = convertToString(filename, sourceStr);
        return 1;
const char * source    = sourceStr.c_str();
    size_t sourceSize[]    = { strlen(source) };
program = clCreateProgramWithSource(
                  context,
                  1,
                  &source,
                  sourceSize,
                  &status);
        mexPrintf("Error: Loading Binary into cl_program \
               (clCreateProgramWithBinary)\n");
      return 1;
/* create a cl program executable for all the devices specified */
	char* build_log;
	size_t log_size;
    status = clBuildProgram(program, 1, devices, NULL, NULL, NULL);
        mexPrintf("Error: Building Program (clBuildProgram)\n");
		// First call to know the proper size
		clGetProgramBuildInfo(program, devices[0], CL_PROGRAM_BUILD_LOG, 0, NULL, &log_size);
		build_log = new char[log_size+1];
		// Second call to get the log
		clGetProgramBuildInfo(program, devices[0], CL_PROGRAM_BUILD_LOG, log_size, build_log, NULL);
		build_log[log_size] = '\0';
		mexPrintf("%s\n", build_log);
		delete[] build_log;
        return 1;
/* get a kernel object handle for a kernel with the given name */
    kernel = clCreateKernel(program, "sts_kernel", &status);
        mexPrintf("Error: Creating Kernel from program. (clCreateKernel)\n");
        return 1;
return 0;
I really need to get this going…any help would be highly appreciated. This code work perfectly fine on ATI Radeon but does not run on GTX 260.
regards,
Richeek
