Hi all,
Any advice regarding the physical cleaning of the Jetson Tx2 board? I was thinking to use ultrasound cleaner. Is possible to damage components from the board or is safe?
If you have used different ways can you please advise me.
Hi, did you meet any issue so that you want to clean the board? In general, for the board that is not underfilled, it should be careful to do such clean.
