When I have 2 nodes communicating with each other, i have no problem sending or receiving the messages. I have the tick function called on message received. This seems to work fine as well.
In the tick function I have if(rx_example().available()). This is set properly as well. The problem that occurs is that after one message is receive, there is always a message available, regardless if new or not. Is there a way to remove read messages?
I did see there is a processNewmessages callback that claims it marks all messages as read but then I would need to set up a call back function which seems redundant if the tick is going to occur on message receive anyways. Does this make rx_example().available() return FALSE if using this call? Is this really the only way? Can I not manually reset a message flag myself?
