ClearSightNet model
• Hardware Platform (Jetson / GPU) Jetson Orin Nano
• DeepStream Version 6.4
• JetPack Version (valid for Jetson only) 6.2 DP
• TensorRT Version
• Issue Type( questions, new requirements, bugs) questions
Hello everyone,
I would like to inquire about the availability of the ClearSightNet model. If it is not currently available, could you please provide information on whether it will be made accessible in the future?
Thank you.
Are you working on DriveWorks? Why do you need the ClearSightNet model?
No, I don’t work with DriveWorks. I work with DeepStream in various applications/use cases. I am looking for a pre-trained model capable of detecting if the camera is obstructed by dirt or water, for example, and/or identifying if the field of view is not at 100% due to various atmospheric conditions. I came across the ClearSightNet presentation, which seemed to be the ideal solution for what I was looking for. Since it’s a DNN, I assumed I could use it in DeepStream if I had access to the model. Hence, my question about whether it will be made available.
The ClearSightNet is a part of DriveWorks, please consult DriveWorks whether they can provide the model separately.
Latest DRIVE PX 2/DriveWorks topics - NVIDIA Developer Forums
