clEnqueueNDRangeKernel call takes too much time on Nvidia GPUs
Hello. I use OpenCL in my program to build finite element method SLAE. Algorithm is implemented using one OpenCL kernel. The problem is when running this code on Nvidia GPUs clEnqueueNDRangeKernel function call takes way more time than on other devices. Kernel execution time is obtained by calculating ..._END - ..._START from clGetEventProfilingInfo. I get the same value by measuring clWaitForEvents.
There is a method (let’s name it BuildSymDiagSlae) which
  1. Creates OpenCL buffers with CL_MEM_COPY_HOST_PTR flag.
  2. Calls clEnqueueNDRangeKernel
  3. Calls clWaitForEvents on event returned by 2.
  4. Calls clEnqueueReadBuffer to read produced SLAE in CSharp arrays.
I measured each step on AMD GPU (ROCm), Intel iGPU (intel-compute-runtime) and Nvidia GPU (NVIDIA CUDA).
On Intel and AMD devices step 2 takes less that 1ms for any size of generated SLAE. e.g. these are the results of generating a SLAE of size 4198401 on RX570:
Transfer Host->Device: 30ms
Enqueue: 0ms
Wait: 18ms
Transfer Device->Host: 50ms
Same function call on laptop GTX 1660 Ti with OpenCL 3.0 CUDA 12.8.97:
Transfer Host->Device: 111ms
Enqueue: 49ms
Wait: 17ms
Transfer Device->Host: 36ms
RTX 2060 with OpenCL 3.0 CUDA 12.6.65:
Transfer Host->Device: 36ms
Enqueue: 45ms
Wait: 20ms
Transfer Device->Host: 26ms
Is it expected that clEnqueueNDRangeKernel takes so much time?
At least in CUDA, the first time you launch a particular kernel, there may be some overheads. I don’t think they would normally amount to milliseconds, but I haven’t surveyed the space much.
What I observe with a simple OpenCL test case (derived from the code here) is a somewhat longer first-time kernel launch overhead of ~150 microseconds followed by subsequent launches in the range I would expect, around 15 microseconds:
# cat t3.cpp
#include <CL/opencl.h>
#include <stdint.h>
#include <stdio.h>
#include <inttypes.h>
#include <stdlib.h>
#include <iostream>
#include <time.h>
#include <sys/time.h>
#define USECPSEC 1000000ULL
unsigned long long dtime_usec(unsigned long long start=0){
  timeval tv;
  gettimeofday(&tv, 0);
  return ((tv.tv_sec*USECPSEC)+tv.tv_usec)-start;
const char source[] =
"__kernel void test_rotate(__global ulong *d_count, ulong loops, ulong patt)"
"  ulong n = patt;"
"  for (ulong i = 0; i<loops; i++)"
"    n &= (107 << (patt+(i%7)));"
"  d_count[0] = n + loops;"
int main(int argc, char *argv[])
  cl_platform_id platform;
  cl_device_id device;
  cl_context context;
  cl_command_queue queue1, queue2;
  cl_program program;
  cl_mem mem1, mem2;
  cl_kernel kernel;
  bool two_kernels = false;
  unsigned long long loops = 1000;
  if (argc > 1) loops *= atoi(argv[1]);
  if (argc > 2) two_kernels = true;
  if (two_kernels) printf("running two kernels\n");
  else printf("running one kernel\n");
  printf("running  %lu loops\n", loops);
  unsigned long long pattern = 1;
  clGetPlatformIDs(1, &platform, NULL);
  clGetDeviceIDs(platform, CL_DEVICE_TYPE_ALL, 1, &device, NULL);
  context = clCreateContext(NULL, 1, &device, NULL, NULL, NULL);
  queue1 = clCreateCommandQueue(context, device, CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE, NULL);
  queue2 = clCreateCommandQueue(context, device, CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE, NULL);
  const char *sources[1] = {source};
  program = clCreateProgramWithSource(context, 1, sources, NULL, NULL);
  clBuildProgram(program, 1, &device, NULL, NULL, NULL);
  mem1 = clCreateBuffer(context, CL_MEM_READ_WRITE, 1*sizeof(cl_ulong), NULL, NULL);
  mem2 = clCreateBuffer(context, CL_MEM_READ_WRITE, 1*sizeof(cl_ulong), NULL, NULL);
  kernel = clCreateKernel(program, "test_rotate", NULL);
  const size_t work_size[1] = {1};
  clSetKernelArg(kernel, 0, sizeof(mem1), &mem1);
  clSetKernelArg(kernel, 1, sizeof(loops), &loops);
  clSetKernelArg(kernel, 2, sizeof(pattern), &pattern);
  unsigned long long dt = dtime_usec(0);
  clEnqueueNDRangeKernel(queue1, kernel, 1, NULL, work_size, work_size, 0, NULL, NULL);
  dt = dtime_usec(dt);
  std::cout << "enqueue time: " << dt << " microseconds" << std::endl;
  if (two_kernels){
    clSetKernelArg(kernel, 0, sizeof(mem2), &mem2);
    clEnqueueNDRangeKernel(queue2, kernel, 1, NULL, work_size, work_size, 0, NULL, NULL);
  cl_ulong *buf1 = (cl_ulong *)clEnqueueMapBuffer(queue1, mem1, true, CL_MAP_READ, 0, 1*sizeof(cl_ulong), 0, NULL, NULL, NULL);
  cl_ulong *buf2 = (cl_ulong *)clEnqueueMapBuffer(queue2, mem2, true, CL_MAP_READ, 0, 1*sizeof(cl_ulong), 0, NULL, NULL, NULL);
  printf("result1: %lu\n", buf1[0]);
  printf("result2: %lu\n", buf2[0]);
  dt = dtime_usec(0);
  clEnqueueUnmapMemObject(queue1, mem1, buf1, 0, NULL, NULL);
  clEnqueueUnmapMemObject(queue2, mem2, buf2, 0, NULL, NULL);
  return 0;
# nvcc -o t3 t3.cpp -lOpenCL
In file included from /usr/local/cuda/bin/../targets/x86_64-linux/include/CL/opencl.h:24,
                 from t3.cpp:1:
/usr/local/cuda/bin/../targets/x86_64-linux/include/CL/cl.h:26:104: note: ‘#pragma message: cl_version.h: CL_TARGET_OPENCL_VERSION is not defined. Defaulting to 300 (OpenCL 3.0)’
   26 | _TARGET_OPENCL_VERSION is not defined. Defaulting to 300 (OpenCL 3.0)")
t3.cpp: In function ‘int main(int, char**)’:
t3.cpp:44:22: warning: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 2 has type ‘long long unsigned int’ [-Wformat=]
   44 |   printf("running  %lu loops\n", loops);
      |                      long unsigned int
      |                    %llu
t3.cpp:49:32: warning: ‘_cl_command_queue* clCreateCommandQueue(cl_context, cl_device_id, cl_command_queue_properties, cl_int*)’ is deprecated [-Wdeprecated-declarations]
   49 |   queue1 = clCreateCommandQueue(context, device, CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE, NULL);
                 from t3.cpp:1:
/usr/local/cuda/bin/../targets/x86_64-linux/include/CL/cl.h:1980:1: note: declared here
 1980 | clCreateCommandQueue(cl_context                     context,
t3.cpp:50:32: warning: ‘_cl_command_queue* clCreateCommandQueue(cl_context, cl_device_id, cl_command_queue_properties, cl_int*)’ is deprecated [-Wdeprecated-declarations]
   50 |   queue2 = clCreateCommandQueue(context, device, CL_QUEUE_OUT_OF_ORDER_EXEC_MODE_ENABLE, NULL);
                 from t3.cpp:1:
# ./t3
running one kernel
running  1000 loops
enqueue time: 144 microseconds
result1: 1000
result2: 0
enqueue time: 13 microseconds
(CUDA 12.2, driver 535.86.10, L4 GPU)
If the internals are similar to CUDA, a noticeable part of OpenCL launch overhead may be due to single-threaded CPU activity, with the hardware limit (by observation, this appears to be ≈ 2 microseconds with CUDA on recent GPU architectures) reached only on the fastest host platforms (e.g. Intel Xeon 6, AMD Zen 5).
If launch overhead is a concern for overall application performance, this may be an aspect worth exploring and characterizing.
The measured results in the dozens of milliseconds reported in the question do not make sense to me. I would recommend double checking whether microseconds were inadvertently confused with milliseconds.
My code is available here: GitHub - RocketRide9/course_opencl (sorry for the mess…)
I’m pretty sure time is measured in milliseconds, it’s ElapsedMilliseconds: SparkCL/SparkCL/Kernel.cs at 9613cb817a14261ee3071e7c86b4dbc028784cb5 · RocketRide9/SparkCL · GitHub
Kernel for SymDiag SLAE builder is being set up and enqueued here: course_opencl/Course/SlaeBuilder/SymDiagSlaeBuilder.cs at 3935b116ee8f0dd25888d3c6d4065e6ed0f68a30 · RocketRide9/course_opencl · GitHub
If you would like to run this project, you need to install dotnet9 and clone this repo with submodules e.g. git clone --recurse-submodules https://github.com/RocketRide9/course_opencl.git. It can be launched by pressing “play” button in Visual Studio (Code) or by executing ./Course/run.sh --release.
Time measurements are going to appear in Course/measurements. Mentioned SymDiag builder is going to appear at line 1236. On my AMD machine I get:
SymDiag Builder: OpenCL
    Init: 32ms
        Kernel prepare: 0
        Transfer Host->Device: 90
        Setargs: 0
            Enqueue: 0 <--
            Wait: 19
        Build time: 19ms
        Transfer Device->Host: 84
        0->1 on diag: 9ms
    Build: 203ms
    Conds: 2
ProblemLine.Build total: 238
OpenCL Tracing: 19ms + 76ms
I had a similar problem recently. Timing `clEnqueueNDRangeKernel` on the CPU side showed that it took something like 17ms to finish that enqueue call, which is way higher than it reasonably should be. The problem was that one of the arguments to this kernel was a buffer that was allocated with `CL_MEM_USE_HOST_PTR`. The way that flag is currently implemented is that the copy of the buffer content does not start on the call to `clCreateBuffer`, but at the first time of use, which in this case is the enqueue call. So the way to keep the enqueue times short is to do the transfers of buffers explicitly.
