Continuing the discussion from Jetson Orin Power GUI will not come up:
Here, I met the same problem which the Jetson Power GUI can’t open, unfortunately some error prompted when I input command below,
sudo /usr/share/nvpmodel_indicator/nvpmodel_indicator.py
The logs are different if it was entered in different terminals. while in SSH terminal the log was,
MoTTY X11 proxy: Unsupported authorisation protocol
Unable to init server: Could not connect: Connection refused
(nvpmodel_indicator.py:3054205): Gtk-CRITICAL **: 19:16:16.609: gtk_icon_theme_get_for_screen: assertion 'GDK_IS_SCREEN (screen)' failed
/usr/share/nvpmodel_indicator/nvpmodel_indicator.py:237: Warning: invalid (NULL) pointer instance
indicator = appindicator.Indicator.new(INDICATOR_ID, ICON_DEFAULT,
/usr/share/nvpmodel_indicator/nvpmodel_indicator.py:237: Warning: g_signal_connect_data: assertion 'G_TYPE_CHECK_INSTANCE (instance)' failed
(nvpmodel_indicator.py:3054205): Gtk-CRITICAL **: 19:16:16.616: _gtk_style_provider_private_get_settings: assertion 'GTK_IS_STYLE_PROVIDER_PRIVATE (provider)' failed
Segmentation fault
While in terminal window on AGX Orin desktop,
(nvpmodel_indicator.py:3058292): libappindicator-WARNING **: 19:21:08.118: Unable to get the session bus: Could not connect: Connection refused
(nvpmodel_indicator.py:3058292): LIBDBUSMENU-GLIB-WARNING **: 19:21:08.118: Unable to get session bus: Could not connect: Connection refused
How can I fix this problem and make Jetson Power GUI working properly?
