It looks like my original post on this was closed, so I’m posting again. Here’s the original post, so I won’t have to reiterate it:
https://forums.developer.nvidia.com/t/clock64-return-value-incorrect-when-debugged/269270
The last request was for some system-identifying data. I was able to get access to the system again, so here it is:
orion
description: Computer
product: Jetson AGX Orin Developer Kit
vendor: Unknown
version: Not Specified
serial: 1421122110254
width: 64 bits
capabilities: smbios-3.0.0 dmi-3.0.0 smp tagged_addr_disabled
configuration: boot=normal family=Unknown sku=Unknown
*-core
description: Motherboard
vendor: Unknown
physical id: 0
slot: Unknown
*-cache:0 DISABLED
description: L1 cache
physical id: 6
slot: L1 Instruction Cache
capacity: 64KiB
capabilities: internal instruction
configuration: level=1
*-cache:1 DISABLED
physical id: 1
slot: L1 Data Cache
capacity: 64KiB
capabilities: internal data
*-cache:2 DISABLED
description: L2 cache
physical id: 2
slot: L2 Cache
capacity: 256KiB
capabilities: internal unified
configuration: level=2
*-cache:3 DISABLED
description: L3 cache
physical id: 3
slot: L3 Cache
capacity: 2MiB
configuration: level=3
*-cpu:0
description: CPU
product: ARMv8 (Not Specified)
vendor: Not Specified
physical id: 4
bus info: cpu@0
serial: Not Specified
slot: CPU01
capacity: 2201MHz
clock: 31MHz
capabilities: lm cpufreq
configuration: cores=12 enabledcores=12 threads=1
*-firmware
description: BIOS
vendor: EDK II
physical id: 5
version: 4.1-33958178
date: 08/01/2023
capabilities: pci pnp upgrade shadowing cdboot bootselect acpi uefi
*-memory
description: Generic Memory
physical id: b
capacity: 32GiB
*-cpu:1 DISABLED
description: CPU
product: cpu-map
physical id: 7
bus info: cpu@0
*-cpu:2 DISABLED
description: CPU
product: cpu
physical id: 8
bus info: cpu@1
capacity: 2201MHz
capabilities: cpufreq
*-cache
description: L1 Cache
physical id: 0
*-cpu:3 DISABLED
description: CPU
product: cpu
physical id: 9
bus info: cpu@2
capacity: 2201MHz
*-cache
physical id: 0
*-cpu:4 DISABLED
description: CPU
product: cpu
physical id: a
bus info: cpu@3
capacity: 2201MHz
*-cache
physical id: 0
*-cpu:5 DISABLED
description: CPU
product: cpu
physical id: c
bus info: cpu@4
capacity: 2201MHz
*-cache
physical id: 0
*-cpu:6 DISABLED
description: CPU
product: cpu
physical id: d
bus info: cpu@5
capacity: 2201MHz
*-cache
physical id: 0
*-cpu:7 DISABLED
description: CPU
product: cpu
physical id: e
bus info: cpu@6
capacity: 2201MHz
*-cache
physical id: 0
*-cpu:8 DISABLED
description: CPU
product: cpu
physical id: f
bus info: cpu@7
capacity: 2201MHz
*-cache
physical id: 0
*-cpu:9 DISABLED
description: CPU
product: cpu
physical id: 10
bus info: cpu@8
capacity: 2201MHz
*-cache
physical id: 0
*-cpu:10 DISABLED
description: CPU
product: cpu
physical id: 11
bus info: cpu@9
capacity: 2201MHz
*-cache
physical id: 0
*-cpu:11 DISABLED
description: CPU
product: cpu
physical id: 12
bus info: cpu@10
capacity: 2201MHz
*-cache
physical id: 0
*-cpu:12 DISABLED
description: CPU
product: cpu
physical id: 13
bus info: cpu@11
capacity: 2201MHz
*-cache
physical id: 0
*-cpu:13 DISABLED
description: CPU
product: cpu
physical id: 14
bus info: cpu@12
*-cache
physical id: 0
*-cpu:14 DISABLED
description: CPU
product: cpu_core_power_states
physical id: 15
bus info: cpu@13
*-pci:0
description: PCI bridge
product: NVIDIA Corporation
vendor: NVIDIA Corporation
physical id: 100
bus info: pci@0001:00:00.0
version: a1
width: 32 bits
clock: 33MHz
capabilities: pci pm msi pciexpress msix normal_decode bus_master cap_list
configuration: driver=pcieport
resources: irq:64 ioport:1000(size=4096) memory:20a8000000-20a80fffff
*-network DISABLED
description: Wireless interface
product: RTL8822CE 802.11ac PCIe Wireless Network Adapter
vendor: Realtek Semiconductor Co., Ltd.
physical id: 0
bus info: pci@0001:01:00.0
logical name: wlan0
version: 00
serial: ec:2e:98:ca:55:79
width: 64 bits
clock: 33MHz
capabilities: pm msi pciexpress bus_master cap_list ethernet physical wireless
configuration: broadcast=yes driver=rtl88x2ce driverversion=5.10.120-rt70-r35.4.1-tegra-Red latency=0 multicast=yes wireless=unassociated
resources: irq:312 ioport:1000(size=256) memory:20a8000000-20a800ffff
*-pci:1
physical id: 0
bus info: pci@0005:00:00.0
version: a1
width: 32 bits
clock: 33MHz
resources: irq:68 memory:2b28000000-2b280fffff
*-generic
description: System peripheral
product: Concurrent Real-Time
vendor: Concurrent Real-Time
physical id: 0
bus info: pci@0005:01:00.0
version: 01
width: 32 bits
clock: 33MHz
capabilities: msi pm pciexpress bus_master cap_list
configuration: driver=rcim latency=0
resources: irq:308 memory:2b28040000-2b28043fff memory:2b28000000-2b2803ffff
*-usbhost:0
product: xHCI Host Controller
vendor: Linux 5.10.120-rt70-r35.4.1-tegra-RedHawk-8.4.7-trace xhci-hcd
physical id: 1
bus info: usb@1
logical name: usb1
version: 5.10
capabilities: usb-2.00
configuration: driver=hub slots=4 speed=480Mbit/s
*-usb:0
description: Bluetooth wireless interface
product: Bluetooth Radio
vendor: Realtek
physical id: 3
bus info: usb@1:3
version: 0.00
serial: 00e04c000001
capabilities: bluetooth usb-1.00
configuration: driver=rtk_btusb maxpower=500mA speed=12Mbit/s
*-usb:1
description: USB hub
product: 4-Port USB 2.0 Hub
vendor: Generic
physical id: 4
bus info: usb@1:4
version: 1.40
capabilities: usb-2.10
*-usb
description: Keyboard
product: USB Receiver
vendor: Logitech
physical id: 2
bus info: usb@1:4.2
version: 12.09
configuration: driver=usbhid maxpower=98mA speed=12Mbit/s
*-usbhost:1
physical id: 2
bus info: usb@2
logical name: usb2
version: 5.10
capabilities: usb-3.10
configuration: driver=hub slots=4 speed=10000Mbit/s
*-usb
product: 4-Port USB 3.0 Hub
vendor: Generic
physical id: 3
bus info: usb@2:3
version: 1.40
capabilities: usb-3.20
*-network:0 DISABLED
description: Ethernet interface
physical id: 3
logical name: dummy0
serial: 66:9f:46:20:65:9b
capabilities: ethernet physical
configuration: broadcast=yes driver=dummy driverversion=5.10.120-rt70-r35.4.1-tegra-Red
*-network:1
physical id: 4
logical name: eth0
serial: 48:b0:2d:78:04:20
capacity: 10Gbit/s
capabilities: ethernet physical 100bt 100bt-fd 1000bt-fd 10000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=nvethernet driverversion=5.10.120-rt70-r35.4.1-tegra-Red duplex=full ip=10.134.31.140 link=yes multicast=yes port=twisted pair speed=1Gbit/s
*-network:2
physical id: 5
logical name: rndis0
serial: 36:38:0e:26:d6:75
configuration: broadcast=yes driver=g_ether driverversion=29-May-2008 firmware=tegra-xudc link=no multicast=yes
*-network:3
physical id: 6
logical name: usb0
serial: 36:38:0e:26:d6:77
